Frigidaire window unit 12,000btu FRA123CV1 KK24108812
SOURCE: AS12S4GB AIR CONDITIONER 4 BEEPING
when you restart the unit monitor the outdoor unit and see if the compressor and outdoor fan starts up . before the beeps . you can try reseting everything by disconecting all power to outdoor unit .
hope this helps please leave fead back / keep me informed
Have you recently plugged in another appliance (computer, microwave, etc)? The drain on your home's wiring system may not be allowing all appliances to run at once.
Some basic trouble-shooting guidelines can be found at: http://www.repairclinic.com/Air-Conditioner-Troubleshooting
SOURCE: compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
SOURCE: Frigidaire window unit, keeps beeping and turning the fan down to lowest setting
Clean the unit, clean the filter, reset the GFI plug if you have one, and then try again. If you continue to have the same problems, contact Frigidaire and see if you have any limited warranty on the appliance.
Testimonial: "got it thanks for all your help :)"
Good morning jesse dixon, I appreciate your post!
Based off the information you have provided your Frigidaire air conditioner, FRA123CV1, cutting off every three minutes and then flashes "#88" then it will go back to the normal setting. Sounds it could be a possible issue within your control panel or power cord. Are you currently under warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy. I hope this helps to some degree. -Matt
Hello Pete T - From what you have described the air conditioner possibly have a defective power/control board or faulty plug. I would suggest contacting a professional to accurately diagnose and repair the unit.
