Tv will not turn on.. power light blinks when i try to turn the tv on.. and it shows the products name for a split half a second flash on the screen then goes back off.
Number of TV have a bad batch of capacitors on the power board. If you look like split mushrooms that is a bad sign. But there are kits if you know how to solder.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
These blinks are fault codes. To Philips TVs, the way to count these blinks are not direct. It has some procedure. You here say, that it blinks 11. It is not the same number that there should be. Check the site liked here, to know more about how to count these blinking codes to Philips TVs.
Pull up previous posts by its left sidebar, or
type in the brand name and model number to of your set, to its search
box, and press 'Enter' or view it in Mosaic / Timeslide option.
What is the brand name to your TV? Provide more details please. If you wish to get more details, surf this link.
There are more than two thousand and four hundred posts. All are related
to television and other domestic electronic equipment service help. More than
Nine and half Lakh viewers cannot be wrong.
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. It will make
search easy. There are more than 1200 posts to different brand TVs now. Pull up
older posts there. Blinking codes to so many brand TVs are described in detail here.
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
