Very limited help in the link. Most of these chairs have a breaker switch. Flip the breaker off for 5 minutes and then back on. This should reset the control panel. The long way to do it is to remove the negative battery cable.
https://www.pridemobility.com > us_q600_om
PDF
Including Models: Quantum 600 2SP, Quantum 600 2MP, Quantum 600 3S, Quantum ... When driving down an incline, set your power chair to the slowest speed ...
Including Models: Quantum Q6 Edge 3S, Quantum Q6 Edge 3SP, and Quantum Q6 .... Do not place your power chair in freewheel mode while on an incline or decline. ... Do not modify your power chair in any way not authorized by Pride. .... Regenerative - uses electricity to rapidly slow the vehicle when the joystick returns ...
Pride MobilityQuantum 6000 .... WELCOME to Quantum Rehab, a division of Pride Mobility Products ... The symbols below are used on the power chair to identify warnings, .... Lowpressure may result in loss of control, ... If you must stop, start up again slowly and then accelerate .... Avoid tall grass that can entangle the running gear.
Pride Mobilitythis power chair and must perform all of the procedures in this manual. The symbols below are used throughout this owner's manual and on the power chair to identify ... NOTE: The Quantum 6000Z and its components are not made with natural ..... Turn the adjusting screw to raise the front of the armrest or to lower the front ...
www.usatechguide.org/itemreview.php?itemid=1626
Quantum 6000 or 600 Rehab Power Wheelchair - CareCure Communitysci.rutgers.edu/.../showthread.php?...Quantum-6000...Rutgers UniversityJul 4, 2008 - 10 posts - 9 authorsI had the QUANTUM 600e Rehab Power Wheelchair for six months. ... C-500 Hvy dutypower chair w/hi-speed motors, power seating system, .... I have a Q600 with tilt, recline, leg extension, Q-logic..pretty much the works. ... the thing shuts itself off andwon't move when I have anything under 90% charge?Quantum® 600 Power Chair Reviews - Pride Mobilityownersclub.pridemobility.com/reviews/item/1/20The Quantum® 600 Power Chair delivers the stability of patented Mid-Wheel 6® ... At that same time the 3rd motor set was changed my seating system was ... We were rescued by boat and my friends say the wheelchair was working ... Insurance won'tcover a power chair for me yet so I had to pay out of pocket for this one.
The chair is more than likely in free wheel. There are two levers under front of the seat (yellow). Pulling them forward should place the chair in freewheel and pushing the levers back should place the chair in drive. Once in drive mode, turn power on to reset joystick.
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
I just had same code. I took off rear cover and unplugged a rubber cap at the end of a long skinny group of a few wires. looks like a charging wire kinda. and unplugged the main plug. I did not unplug the two larger battery plugs. when I plugged them back in firmly everything was back to normal.
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
