LG 37LG30 37 in. LCD HDTV Logo
A
Anonymous Posted on Jul 19, 2015
How do i remove stand - LG 37LG30 37 in. LCD HDTV
JP Meneide
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • LG Master 483 Answers
  • Posted on Jul 20, 2015
JP Meneide
LG Master
Level 3:
Dedicated:
Answers
483
Questions
Helped
178072
Points
2858
Here is a link on how to put it on. Removal is just the inverse.
LG 223000 Owner Manual Stand Installation
1995 harley Dyna low rider kickstand removal/installation
To remove the stand, you'll need to block up the bike so it'll stay upright while the stand is removed.
Now, there are two ways to remove the stand.
If you want to remove it as an assembly, unhook/remove the spring, and remove the four bolts holding the bracket to the frame:
http://i.ebayimg.com/00/s/OTYwWDEyODA=/z/efIAAOxyx0JTfhs7/$_57.JPG
To remove just the stand's arm, leaving the bracket bolted to the frame, unhook/remove the spring, and remove the nut on the pivot, and the kickstand stop (the part with the squared off peg that fits into the bracket when the stand is down and weight is placed on the stand, when you lean the bike over onto it):
http://i.ebayimg.com/00/s/MjY3WDQwMA==/z/vdcAAOxyQfJTfNWR/$_12.JPG
1helpful
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn [email protected]
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
28helpful
2answers
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
3helpful
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
4helpful
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
2. after the screws are removed, the TV will lift from the stand.
The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
5helpful
2answers
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
2helpful
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
25helpful
2answers
How to remove stand
Just taken the stand off my LG 42LC2D. The stand is made of cast aluminum and has 2 long legs that insert into the base of the TV. So to remove the stand lay the TV on its screen and remove the two screws that are vertically in line next to the power socket the the 2 screws that are vertically in line under the RGB socket. The stand then pulls out from the bottom of the TV.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
