I have not seen this in a long time. 'Way back in
the 1970's a similar problem would occur when the
telephone company accidently reversed the 'tip and
ring' wires. This was only a problem with the
then-new "push button" (tone) dialing, the standad
rotary dials worked fine. The fix was to reverse
the red & green station wires in the "B-block"
(on the baseboard) to undo the central office goof.
Maybe it still happens? Try reversing the red &
green wires in the modular (wall) socket you are
plugging the base ('main unit') into.
ring' wires.
green wires in the modular socket you are plugging
The battery in your phone system is dead. This will happen every time you have a power failure. Everything resets. Date becomes Jan 1st 1980 (but might update if you have callerID), all phones will have access to only line 1 and line 2, both those lines will ring on all calls, and the line settings are set back to pulse ...
Ideally you either have the battery replaced (it's soldered on the board of the system), or you get a new phone system. Otherwise you'll have to reprogram everything when you have a power failure.
Hi - There should be a switch on the phone somewhere that says pulse or tone. Set the phone to tone and things will be back to normal like you expect.
Regards,
Mikeywaf
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise.
in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it..
HAPPY FAXING
HEMANT GROVER
