SanDisk Sansa Clip MP3 Player Logo
A
Anonymous Posted on Jul 18, 2015
I can't download songs using the new rhapsody 6. The old Rhapsody 4 has stopped working too.
I was finally told there is a software glitch that they are working on but message boards indicate this has been going on for over a year. Can/will this be resolved. I can't download new music and have lost most of my old songs. Syncing just seems to go on for hours and hours without downloading new songs. Can't drag songs or albums. The old Rhapsody 4 worked perfectly for years and years. The troubles began with the new app.
5 Related Answers
Anonymous
  • 626 Answers
  • Posted on Oct 10, 2007
SOURCE: music stopped playing "synchronize to continue..."
Your device has to be connected to Rhapsody every 15 to 30 days to verify your account.
If you are connected and signed in, and still receive this message, you should contact Rhapsody Technical Support as the error is on their end. (866-597-5507)
Best of Luck.
Anonymous
  • 91 Answers
  • Posted on Nov 09, 2007
SOURCE: no files on sansa m 240 but appear on computer
Try formatting your mp3 player which might fix this problem. Also do some updates from the manufacturers website. This may be a known bug which your mp3 players manufacturer may have found and made a new driver version for.
http://www.sandisk.com/driverdownload/index.asp
To format follow these steps below:
First go to "My Computer" - now look for your mp3 player usually named under for example "Removable Disk F", when you've found it "Right-Click" on it then click on "Format", when format is complete try after that.
Any further problems leave a comment on this page and i will get back to you.
Good luck. Hope my solution was helpful.
pinkplumeria
  • Posted on Apr 26, 2008
SOURCE: vista not compatible with rhapsody.
I use Rhapsody with Vista. You need to go to Rhapsody's website (or Best Buy Digital Music Store, which runs the same software) and download the updated version, which will work just fine.
Purchased music from iTunes can be put on Sansa players as well when you set-up Rhapsody to manage your music. Have the program detect your music library and then all you have to do is drag and drop to your MP3 player.
Anonymous
  • Posted on May 28, 2008
SOURCE: Music skipping
hmm. The hard drive itself could be messed up. The hard drive can easily be formatted by right clicking and formatting it. Though I am taking the easy way out here to fix the problem.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jan 01, 2009
SOURCE: Trying to synch my SanDisk MP3 player to Rhapsody
This player is a little goofy. The normal method to synchronize is through Windows Media Player. But if you go for the Rhapsody subscription, you have to also sync the device through Rhapsody.
-Tha Mp3 Doctor
Drm won't install in rhapsody
Rhapsody will not work on an iPhone unless you jailbreak (which is not advisable). Apple wants you to use iPhone. You can use music you bought from Rhapsody and import it to your iTunes and then sync.
I used to work for Apple Tech Support.
Sansa rhapsody mp3 player
Your Windows Media Player may need to be updated and the player may need to be formatted. Please try these steps: 1) If you do not have it installed yet, please install the latest version of WMP10. 2) Download and install the quick fix from: http://download.microsoft.com/download/7/e/0/7e055e3f-6014-43bc-b6ff-6a90ced1d032/WindowsMedia10-KB902344-x86-INTL.exe 3) Format m250 device using the Sync mode in WMP. 4) To test, transfer songs to the player using the software for your subscription music service.
My sansa fuze is telling me i need to synchronize to continue music subscription? What do i do?
Hi There. I can understand your problem.
When we say synchronize it means that the license for the songs which you transfered got expired. If you have chosen rhapsody for transferring songs then follow the steps.
1) Deauthorize Computer. ( In rhapsody menu, go to tools menu there u will find this option)
2) Deauthorize device (By connecting the device in to rhapsody, right click on device where u will get this option).
3) Rename DRM folder in windows OS.
4) Go to rhapsody folder c:/prog files/rhapsody
5) Run the 3 files ( Del Helix License, Update Helix Componetns and Update windows components)
6) Then you will be redirected to the web page where u need to click on upgrade (But before u clilck on upgrade please install the activeX control, which will be popped up below the address bar)
7) Restart the computer
8) Launch rhapsody, it will take u to the setup
9) Follow the on screen instruction.
10) Sign into rhapsody account
11) Authorize computer
12) Connect the device
13) Authorize device
14) Download and transfer new song into the device
15) Unplug the device and try to play it
16) This should work..
NOTE : When we update the windows component please make sure that we use IE as default browser
Still if u have any issues kindly revert
Rhapsody downloads a few songs then stops.
if you want free songs and you have an email address watch this video
When playing my mp3 the songs that i have downloaded off my pc from a paid site, across the screen of the sansa says synchronize to continue your music subsription. the songs will not play please help me
Even though you should be able to resynchronize the files through Rhapsody in order to update the licenses on the music files, in my experience with this player, you have to go through a long, painful process:
1) Open Rhapsody
2) Connect your mp3 player to the computer
3) Delete the songs off the player itself using Windows Media Player - but make sure you still have a copy of these songs on your computer
4) Reload the Rhapsody songs
If your subscription to rhapsody expires, you will no longer be able to use the songs unless you buy them from the Rhapsody Mp3 Store.
-Tha Mp3 Doctor
1helpful
2answers
Not playing songs/ transferring to MP3 player on Rhapsody.
You probably have to redownload the songs again. Forget about the pictures, this player is pretty buggy, it's not worth it.
Music transfer
Here is what is going on. All iTunes songs are in AAC format. The Insignia Pilot cannot read thos files, and the Rhapsody music service cannot read them either. You will need to redownload all of the songs that you want in Rhapsody itself. If you do not want to pay the monthly fees, then I would not download any songs from Rhapsody - they will cease to work after your Rhapsody subscription expires.
You have a couple of options. You could buy an AAC to Mp3 Converter software - this is not free, as far as I know - you also want to be careful, because some sites that advertise these products are scam artists - they don't let you try the product before buying.
Another option is to get Limewire or Morpheus - the free versions of thse services run extremely slow and give you a lot of ads, but they allow you to download Mp3 format songs for free without monthly fees.
Mp3 players just aren't as easy as they used to be.
-Tha Mp3 Doctor
3answers
Can't download songs
I don't really know how Rhapsody works - do you have to download strait from the site to player, or do you save the files to your hard drive in between. If you have them as individual mp3 or wav files on your hard drive try using a different media player.
I did read in the installation guide for my ma566 that its not compatible with downloads "purchased from" itunes. Maybe its the same thing with Rhapsody?
Re: the xp vs win98 - on a phone call to Nextar tech support, I was told that if you have XP you don't need to use the driver disk but you might need to help the computer search online for updated drivers. I'm not sure if your saying your issue is that your COMPUTER is acutally 98 when it was "supposed to be" Xp, or if you are trying to use the 98 driver disk on xp and its not working.
Did your computer ever even recognize that the mp3 player existed? Or are you getting a specific error message?
Will eventually lose songs downloaded?
Okay, here's what i've encountered:  songs that I downloaded on rhapsody, without purchasing, only lasted about 7-10 days unless i reconnected.  once my trial period ended, i lost all the songs.  songs that i've purchased i've had no trouble (although if you load them to the sansa immediately after download, you may get the same message.  its best to wait at least 24 hours).  good luck
3answers
SansaE250 Startup and intial setup problems
download the latest firmware from 7/?/2002
I had this problem too and tried all kinds suggested solutions. The main problem was that no computer would recognize the e250 in MTP mode--which is what you need to transfer songs with DRMs from Rhapsody or similar services. The latest firmware fixed the problem.
I gave up on the whole thing about about a year ago. What a waste of precious time that could have been spent in nerdy musical bliss.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
