It was working good and all of a sudden it just stopped as if it were un plugged. Now it won't turn on when plugged in.
Make sure that power is reaching the motor after going thru the thermostat.
If juice is there replace the starting capacitor. If the motor gets hot but still does not run the rotor might be frozen - check with ammeter for abnormal current draw.
If compressor is frozen all you can do is replace unit.
SOURCE: kenmore 18 cu ft chest freezer
A chest freezer is a very simple machine. There are no fans or defrost system to cause a problem.
You need to make sure the thermostat is not turning off to soon.
If the compressor is running but it does not cool, then there is a problem with the refrigerant system.
You will want to check around with some local repair services, but about the cheapest you would have it repaired will be around $250. That is if it can be repaired at all. The majority of the refrigerant lines are inside the cabinet and unrepairable.
Post back if you have any questions.
SOURCE: Used chest freezer not cooling
Slobberlips,
One of two situations has occured with your used freezer:
1: The unit freon needs to be recharged, this happens when you develope a leak in the freon coils, or the unit is old enough that the freon has reached it's usable potential.
2: The compressor may seem to run fine, but in fact, has an internal problem.
My suggestion, return the unit if you can, and walk the isles of your local Menards, Sears, or any other local vendor in your area, and see how much prices have declined for the chest freezer.
The initial investment for a new freezer will offset any problems you might have with any other used unit, and the warranty is always a plus if you do have problems with the new unit.
Hope this helps you out.
SOURCE: Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
