When I power up the car, the screen is supposed to fully slide out and tilt up. Now, it's only coming out about half-way and stopping. Why???
SOURCE: cant slide to Unlock
try holding down the "power" and "home"buton untill you i pod shows the apple logo then try again it will take about 1 too 3 mins to restart
hope this helps
dale gough
SOURCE: iPhone slider won't slide all the way across
I'm having the same issue, have you found any solution?
SOURCE: My ipod touch screen is frozen on "slide to
Restarting the ipod after it has frozen is a simple 5 step process.
Sources: http://ipod.about.com/od/troubleshootingyouripod/qt/ipod-touch-reboot.htm
I hope that information above has helped is some way.
If possible please rate this solution.
SOURCE: The menu and contacts touch buttons on the sliding
Just press any key and press the power key when slide is down........ The buttons will work without sliding up.........
SOURCE: touch screen stopped working
my touch screen stoped working i can still use all keys also i feel vibrate when touch the screen
helppp
