I am replacing the thermostat on my freezer. Since I am replacing it I've decided to upgrade to a digital controller so I may have greater control on how the freezer operates and it's electricity consumption. The new thermostat temperature probe is different than the factory made version. The factory made version appears to be a solid piece of metal which is insulated and connected to the dial changes. The digital version I need to install uses a pair of wires connected to a metal probe about 3 inches long. I am asking how I should disconnect / remove the factory made thermostat probe so I don't damage the freezer. The compressor is still good. Is this as simple as tugging it out and then silicone the new one into place? Does anyone know if it is secured into place ... perhaps by welding or soldering? Thank you very much for any details you are able to provide.
SOURCE: Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
SOURCE: wiring diagram for danby thermostat freezer
Doesn't matter thermostat is just a switch operated by temperature.
