Dryers Logo
s
sandra porazzoperry Posted on Jul 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the corrective action for code E64? - Dryers
Thomas Perkins
Level 3:
  • Master 15,088 Answers
  • Posted on Jul 17, 2015
Thomas Perkins
Master
Level 3:
Answers
15088
Questions
0
Helped
3386461
Points
54869
Toshiba AW-DUK1500WUP-NR(KK) 14.0kg Top Load Washing Machine. ERROR E64 WITHOUT PLAYING IT
My washer dryer combo is showing an error code e64, I
JustAnswer https://www.justanswer.com > Appliance Repair
Aug 13, 2023 - 1. Unplug the unit from its power source. 2. Alternatively, switch off the electrical breaker associated with the unit. 3. Allow a duration of ...
1 answer · Top answer: Thank you for sharing this information. It appears that the unit's placement within a ...
Missing: AW- ‎ DUK1500WUP-
How to Fix Frigidaire Dryer e64 Error Code
Fred's Appliance Academy https://academy.fredsappliance.com > news > how-to-f...
Nov 1, 2021 - If your Frigidaire dryer is displaying an e64 error code, it means the dryer is sensing there is a problem with the heating element.
Jan 12, 2024 • Dryers
2answers
Error code e64 dryer Electrolux FFSE5115PW2
How to Fix Electrolux Dryer Error Code E64
Appliance Express https://applianceexpresstx.com > News and Tips
Apr 10, 2023 - If your Electrolux dryer is showing an E64 error code, this means there is a problem with the heating circuit. When this occurs, your dryer ...
Common Electrolux Dryer Error Codes & How to Fix Them
Just-in Time Appliance Repair https://justintimeappliance.com > blog > common-elect...
Feb 3, 2020 - Another of the more common Electrolux dryer error codes, E64 indicates a malfunction with the heater's wiring or the heating element itself.
How To Fix Frigidaire & Electrolux Dryer Error Code E63 E64
howtofixit.net https://howtofixit.net > how-to-fix-frigidaire-electrolu...
Oct 18, 2020 - These E63 or E64 error codes generally mean that you have an issue with the heating element ...
Videos for E64 Error.
How do I get rid of code? I have an Electrolux front load dryer model #EIMED55IIWO, with E 64 error code. When initially starting the dryer I cancel the code and start the dryer.
E64 error code Electrolux dryer! E64 fault code on your home Electrolux clothes dryer. What this code stands for is that you have a shorted heating element. Other Possible fault: Heater thermostat faulty: Wiring faulty; Electronic board faulty.
https://advancedappliancesolutions.com/e64-error-code-electrolux-clothes-dryer/
https://www.youtube.com/watch?v=ErDSsjVywwg
What is wrong with a code e64
It probably requires a technician to test it.
You haven't identified the manufacturer and model, but it is likely the following result of a Google.com search suggests a problem:
https://www.justanswer.com/appliance/7f3w8-frigidaire-dryer-e64-error-code-dryer-will.html
Why Am Getting Error Code E64 On My Frigidaire Dryer
Mar 19, 2018 • Dryers
Sumsung e64 error code
The e64 fault code commonly indicates defective dryer heating element or wiring to it.
Mar 05, 2018 • Dryers
Why does my frigidaire dryer run briefly then stop and show a code of E64
Hello Robert, I appreciate your post!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E64". An "E64" error code means that the heater has an open circuit this could be an issue with your heater, wiring harness, or a miscommunication within your control panel. To help clear out any miscommunications I would suggest performing a reset. You can reset the dryer by disconnecting power from it for at least ten minutes. If the reset does not help clear out the error code, you may need to seek assistance from a professional technician. This will help you avoid any unnecessary part purchases. I hope that this information is helpful to some degree. -Matt
E64 error code electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
1helpful
2answers
What is error code E64 and how can it be fix
Good Afternoon Friend, this is Z. Thank you for your inquiry!
Normally error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Top Dryers Experts
john h
