Thank you for your inquiry, friend!
Based off what you have described your Frigidaire refrigerator's icemaker is not filling with water and it is still dispensing from the door. Sometimes if the filter is bad water may still dispense but will not make ice. It is recommended to change out the water filter every six to nine months.
You can also pull the refrigerator out from the wall and check the fill tube to make sure it is not frozen. The fill tube is a green line that connects to the upper right corner of your refrigerator. Make sure to turn off the water before checking the line. You should be able to grab the line and twist 45 degrees counter clockwise to pull the tube out. Check and make sure no ice has formed, if ice has built up inside of the line hold the tube in your hand for three to five minutes to loosen it out and remove it. To reinstall the tube insert it back and twist it 45 degrees clockwise. Hopefully this is helpful. -Matt
