Kenwood Kmix Kmx51 Stand Mixer Logo
Carol Wink Posted on Jul 16, 2015
How to get into the gearbox - Kenwood Kmix Kmx51 Stand Mixer
tip
GEARBOX DRIPPIN OIL KENWOOD CHEF
IF YOUR GEARBOX IS DRIPPING OIL TRY CHANGING THE GREASE INSIDE WITH SUPERLUPE FOODSAFE GREASE.AS YOUR OLD GRESE HAS PROBABLY BROKE DOWN AND LIQUIFIES. ALSO CHANGE OR WASH AND DRY THE FELT COVER UNDER GEARBOX.
**** AT KENWOODCHEFUSEDMIXERSANDSPARES.
07507400101
on Jan 05, 2010 • Food Mixers
1helpful
How do you change grease in gearbox ?
You open the gearbox up and scrape it out with your hand and maybe a screwdriver, then replace with the correct grease. For example Kitchen Aid use food grade grease.
Jul 15, 2015 • Food Mixers
How to change grease in gearbox
How to pull auger drive shaft for Hobart 4346 mixer-grinder?
The oil seal is the resistance you feel. take a soft mallet or hammer with a soft drift and gently but firmly tap the stub shaft and it will drive out the oil seal in the hopper direction.The lower skirt of the tapered bearing is what contacts the seal so go slow.
Worked for me.
Accessing gearbox in Hobart N50 (older model)
Take the back cover off the motor and then there will be four nuts that hold on the back bearing cage of the motor. After removing that, you will find 7 large screws in beside the motor that remove the gearbox.
I have oil leaking from the beater shaft. a lot
TRY REPLACING GREASE IN GEARBOX AND MAKE SURE YOUR FELT COVER IS IN PLACE (AND CLEAN) THAT SITS UNDER GEARBOX.
**** KENWOODCHEFUSEDMIXERSANDSPARES
2answers
Kenwood Major Model number A707/A
Hello in ebay, you can get a gearbox for A701/A models ..
if you Kenwood is 1962 - 1975 is A701/A
looking the gearbox for this model. or in Billingtonelec.co.uk
Regards
Kenwood Chef Restore
1helpful
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
Gearbox input toothed cog
I don´t think you can get a new one, you have to replace the gearbox on the machine.
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
