SOURCE: On-line User Manual "Kenmore 3.8 cu. ft. HE3t Washer
I have the Service Technician Diagnostic Guide...it was located behind the lower front panel on the right hand side. It's not really a user manual, but wasn't sure what info you needed that you hoped might be in the user manual, as opposed to a Diagnostic Guide.
SOURCE: What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
SOURCE: How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
SOURCE: I would like to know what the cu capacity is on my Kenmore washer
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%$%
