SOURCE: were can i get a tent manual for a ozark trail
Not sure if they have the exact manual you need but i found a manual for my ozark trail tent at www.ozarkt-trail-tents.com
SOURCE: I have a two man Ozark tent. How do I set it u p?
Two poles. They pass up through the sleeves on the outside of the tent, across the top, through the sleeve on the diagonally opposed side, then each end is stuck into the pocket attached at each corner. They cross at the top. Then the small rain fly attaches with bungees over the top.
SOURCE: I'm looking for replacement poles
Call 1 888 280 7876 M-F 8am to 5pm CST with the model number and they should be able to help you get replacements poles. Note: I have the same tent and the poles cracked after only a few times camping. I believe they are of poor quality and it may not be worth the cost to replace them considering the entire tent costs appx $50 at Walmart new. (Check out the reviews at Walmart.com!)
SOURCE: I need the instructions for a ozark trail 13x9 cabin tent please help
https://www.youtube.com/watch?v=PmZx-p3fYkk
or
https://sites.google.com/site/tentinstructions/home/instructions-for-the-ozark-trail-jw-1390-2-room-cabin-tent
or
http://www.manualslib.com/manual/116615/Ozark-Trail-Wmt-1390s-1.html
How to set up an Ozark Trail 11ft X 8ft Dining Canopy
It is best to have two people assemble this.
Rods:
4 Side Gables: 2, 2b
3 Rafters Across: 1, 1b. 1b
4 Legs: 1, 1B & 3B
The pieces were not labeled so I used a label maker and permanent marker to label the rods and connectors. The plastic connectors do label the legs and gables but don’t label the rafters.
1.Connect a 2 and 2b rod to create a Side Gable. Repeat with the other three 2 and 2b rods.
2.Insert the four Side Gables into the two unmarked connectors (written with a G) to make the pitch of the roof.
3.Connect a 1 rod with two 1b rods to create a Rafter. Repeat to create two more rafters.
4.Insert two Rafters into the 4 corner connectors (written with an R) to form a rectangle frame.
5.Insert the last Rafter in the center connectors to support the peak of the roof.
6.Connect a 1 with two 1b rods to create a leg and repeat to complete the four legs.
7.Inset the legs into the four corner connectors (written with an L).
8.Place the canopy on the frame and use the Velcro tabs on each end to secure in place.
9.Place the hooks (attached to ropes hanging from D Rings) into the appropriate hole on the legs to keep it tight.
10.Stake the canopy to avoid it blowing away.
When assembling alone, put the leg segments into the plastic connectors; pull the canopy over the short frame, then walk around to add the additional leg pieces.
