Bought this PH3100Ri new and it has 250 hours on it... ran great until yesterday. Now it runs but economy switch will not affect rpm runs low rpm, run light not on and it won't produce power, 20 or 30 amp. I've replaced spark plug, drained fuel, changed oil regularly, checked fuel filter... I hate to take it to the shop: 3 week wait.
Hi!
We have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/
If you need any further help our Generator Engineers are happy to assist you.
Regards,The Generator Guru Team
Does anyone have anyone have a fix for this !!
Check the power regulator.
Do you mean the 12v battery charging regulator?
I have the same problem, motor starts but idles at very low rpm, ie only just. Where would I find this regulator and what does it look like?
Did you find a fix? Mine is doing the same
Did anyone find a fix for this
I now have this problem too ... did anyone find the solution?
(i.e. motor starts but idles at very low rpm ... output light not on and no power) Thanks
