RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
J
Janet joa Posted on Jul 15, 2015
The battery charger shows no light.
Battery is not damaged
Trentan Franz
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
  • Posted on May 18, 2016
Trentan Franz
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
10
Questions
0
Helped
12969
Points
25
Plugged in and no light (with or without the battery inserted) tells you that the charger is bad and you will need a new one. Contact ITW Paslode or Fastener's Inc to purchase replacement.
Rexton charger 3g-04 flashing red
The Rexton charger 3g-04 is a device used to charge the batteries in Rexton hearing aids. If the charger is flashing red, it could indicate that there is a problem with the charger or the hearing aid battery.
Some possible causes of a flashing red light on the Rexton charger 3g-04 include:
  1. The battery is not properly seated in the charger: Make sure that the battery is fully inserted into the charger and is making good contact.
  2. The battery is damaged or faulty: If the battery is damaged or has malfunctioned, it may not charge properly.
  3. The charger is damaged or faulty: If the charger is damaged or has malfunctioned, it may not charge the battery properly.
My battery charger is blinking geen not red when Iā€™m trying to charge it. What does that mean?
Hi Linda.
not sure if this will help you out,i found this on the internet.
Battery Charger Troubleshooter
When there is a battery failure, there is a possibility it was caused by a bad battery charger. When the charger is only plugged into the wall, it should show a green light. If there is no light showing, confirm that the outlet is good. If the outlet is good, it is very possible that the issue is with the battery charger, not the battery.
If the charger is plugged into the battery only, it should show a green light. (If you have purchased a new charger within the last year, you will not get a green light if the charger is only plugged into the battery. You will get a green light however if the wall charger is just plugged into the wall and not plugged into the wiring harness) If it does not show a green light, it is likely that the charger is not making contact with the battery. The most likely reason for this is a faulty fuse on the wiring harness. This fuse is a 2-amp automotive fuse, and it should be replaced with a 2 or 3-amp fuse available anywhere that sells auto parts. The fuse can blow out if there is a short in the charging system, or if the plug-in end of the wiring harness comes in contact with a battery terminal.
When the charger is plugged into both an electrical outlet and the battery, there should be a red light showing on the charger. A red light showing indicates that the charger is in contact with the battery and is actively charging the battery. Once the battery has reached a voltage level that is considered "fully charged" the red light changes to green. If after 24 hours the light has not changed to green there is no cause for alarm! Remember that when the light is red, the battery is being charged, and you will be able to use your system. After 24 hours or so, your battery is as charged as it is going to get, and if the light is still showing red you should disconnect the charger and go fishing. Replacement chargers and parts can be purchased directly from MarCum's website.
If you are really concerned about your battery, consider getting a basic volt meter to check the voltage of your battery. They can be bought for less than 20 dollars and will show you exactly what the voltage level of your battery is. If after 24 hours of charging your battery should have at least 12 volts (ideally 13-14 volts) and as long as it is over 12 volts it will work. If it is not at or above 12 volts you should consider replacing the battery. If your unit starts to malfunction while you are fishing, it would not come as a surprise that the voltage has dropped down to 11 volts or lower.
If the charger is plugged into the wall and battery, and you get a blinking light on the charger, it is very likely that the battery is faulty and should be replaced.
Batteries are an expendable item, and must be replaced periodically. Any store that sells ice fishing electronics will stock suitable batteries. You can also buy them at a specialty battery store, or by ordering one from our website.The batteries that you should use are the "Sealed Lead Acid" variety, they are 12 volts, and range from 7 to 9 amps. The more amps the battery has the longer it will run on a full charge. Your MarCum unit can be powered off of any battery that is 12 volts, even a large automotive or deep cycle batteries will work.
or go to this link and have a read up.
battery charger is blinking geen Google Search
Jun 14, 2018 • Cameras
My 40v Ryobi battery will not charge. The charge shows a flat red light that sometimes blinks. The battery shows as charged. It will not work.
Check the battery with your multimeter. If it reads below 36 volts (or whatever the cutoff point is) it may be damaged. But before you run off and buy a new one, use the multimeter to check the voltage from the charger.
Or borrow a good battery and see how your charger behaves.
that way, you can identify the cause of the problem
Tvbp-btn wireless stereo headset. Cannot get it to charge & show blue light. Shows red light when plug into charger; light goes out approx 1 minute later.
If your TVBP-BTN wireless stereo headset is not charging properly and the blue light is not showing, there are a few things you can check to fix the problem.
  1. Check the charger: Make sure that the charger is functioning properly and that the connections are secure. Try using a different charger or USB port to see if that resolves the issue.
  2. Check the charging port: Make sure that the charging port on the headset is not dirty or blocked. Clean it with a dry cloth if necessary.
  3. Check the battery: Make sure that the battery is not damaged or dead. If the battery is damaged or dead, the headset will not charge.
  4. Check for software updates: Make sure that your headset's firmware is up to date, if there is any updates available, install it.
  5. Check the manual: Check the manual that came with the headset for any troubleshooting steps or contact the manufacturer for further assistance.
  6. If you have tried all of the above and the problem persists, it may be a hardware issue, and the headset may need to be repaired or replaced.
My min cota charger model mk105p is jumping from charging light to the green light in rapid ssusession
It is possible that there is an issue with the battery or the charger itself. Here are some possible reasons why your charger may be jumping from the charging light to the green light in rapid succession: Battery Compatibility: The charger may not be compatible with the specific battery you are trying to charge. Double-check to make sure that the battery you are using is compatible with your charger model. Battery Health: The battery may be damaged or defective. Try charging a different battery with the same charger to see if the same issue occurs. Charger Issues: The charger itself may be malfunctioning or defective. Check for any visible damage or loose connections. You may also want to try cleaning the contacts on the charger and battery to ensure proper charging. Overheating: The charger may be overheating, causing it to switch rapidly between the charging and green lights. Make sure that the charger is in a well-ventilated area and not covered while in use. If the issue persists, it may be best to contact the manufacturer or seek assistance from a professional technician to diagnose and resolve the problem.
2helpful
Charger light flashes with no battery charging. I plug the charger into the wall and the damaged battery light flashes. This is a brand new charger one day old.
The charger is damaged. Return it to the place of purchase and demand a refund or replacement. If you paid by credit card call the credit card company and cancel that transaction.
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
I have plugged the Soneil battery charger into the MPV4 Hoveround for over 24 hours. Although the indicator shows charging in process, the "battery charge indicator" shows it still requires a substantial...
If your Power Wheel Chair has been sitting idle for a while, the batts may need to be completely replaced. There is a gel inside the batts that need to have a current run through them via the charger on a regualr basis otherwise it will solidify. If the charger lights are onm you have connected the charger correctly for over 24 hours and the batteries are still not showing they have been charge, there may be damaged cells which means both batteries need to be totally replaced.
2answers
My e900 wont turn on or charge
most likely your charger port is damaged, if you try another charger and get the same thing- then I am sorry but the phone is finished. warranty does not cover damaged ports, but if you have the insurance it is covered under damage, if its lless than a 30 day old problem. If you replace it with the same phone, discard any chargers you used on the old one.
I have an ACER FERRARI laptop. When power plugged in battery light shows, and light also indicates full charge therefore I assume ac lead and battery ok. When pressing start button nothing happens, apart...
the charger might have the problem, and the light that you are seeing apart from the light next to power/battery is the hard disk led, this is showing that HDD is active, your motherboard is not damaged. you might want to check if you need to defrag the Hard disk by right clicking my computer then selecting manage, there you may analyze whether it needs to defrag. now you may check the charger if its chrging by clicking in the taskbar.
Top RTO Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
