Computers & Internet Logo
Patricia Habsburger Posted on Jul 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will a Canon Ax-dc30 fit the Powershot s120 ??
Alex
Level 2:
Champion:
  • Expert 207 Answers
  • Posted on Sep 08, 2015
Alex
Expert
Level 2:
Champion:
Answers
207
Questions
Helped
57404
Points
299
It does not appear to be compatible. See the list of supported cameras from the canon web site:
http://shop.usa.canon.com/shop/en/catalog/ac-adapter-kit-ack-dc30
1helpful
Canon powershot
It really depends on the model of Powershot camera you purchased if it can shoot Raw format or not. I jbelieve the only model available currently that can is the Powershot S120 & G16, the older ones cannot. You can check your models capability at DPReview.com for more information on your camera model.
Dec 22, 2013 • Cameras
Error message setup to address the power of the printer
If there is a message on LCD display to "SET THE ADDRESS" the printer will be fitted with a CO AX/Twin Ax Interface
Press CLEAR to CLEAR the error, then enter the menus on the printer and set an address for the Co-Ax/Twin Ax interface, if you are using this the address would need to match the system set up.
If you are not using Co-Ax/Twin Ax set a random address to clear the error.
Perhaps consider removing the interface if you are not using it
6helpful
2answers
I`ve bought a 4GB memory SDHC memory card to my Canon powershot A 430 camera, and when i put it in my camera - it says memory card error. I tried to unlock it by the small button, but didin`t help. What...
The Canon A430 uses MMC and SD cards. While SDHC cards will fit into the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
1helpful
My Canon PowerShot A560 says that the memory card is locked...even after I change the batteries. What can I do to fix it?
Have you tried the switch on the side of the SD card in both positions? Failing that, the camera will need a new SD slot fitted by repairer.
How do u store linreg(ax+b)as y1 on ur graphic calculater
When you press [STAT] and right Arrow to highlight CALC you see two linear regression model [4:LinReg(ax+b)] and [8:LinReg(a +bx)]
If you select [4: ...] the command echoes on main calculator screen as LinReg(ax+b) and a blinking cursor
If you press [ENTER] you will get your equation, a, b, and r^2 if DiagnosticsOn command has been executed before. However you will not be able to see the line of best fit on top of the raw data scatter plot.
To save the equation of best fit in a function variable, ex Y1, you complete the command as follows
LinReg(ax+b) [VARS][=>][Y-VARS][1:Function][1:Y1]
The Y1 variable will appear on main calculator screen, and you have
LinReg(ax+b) Y1
Press [ENTER]
Screen display the equation, its parameter and its correlation coefficients (if so configured).
Press [GRAPH] to draw the line of best fit on top of the scatter plot.
Here are two screen captures to show you the equation and the line of best fit.
As you can see from the value of r^2, and the graph, a linear regression does not seem good.
ACK DC30 Mains adapter doesn't work
I think these cameras have a small removable rubber cover which will allow you to put a lead in and still close the door. There is a switch on the battery door so it has to be closed for the camera to work!!
Grand Canyon Tech
Grand Canyon Tech
