1) Your disc has dirt or scratches on its surface causing the next mission to be unaccessible. Try to remove your disc and clean it off with a wet cloth. If there is no noticeable damage the proceed try again.
2) It could also be a reading error with the Xbox laser. Shut down the system and try to blow some dust out of the Xbox using compressed air if you have it, otherwise just blow through your mouth.
Judging by your description im guessing its a disc error, clean it the best you can, if it still doesn't work take the game to a game store to have it cleaned professionally.
Lastly, before taking it to a store try and delete your saved data and start a new game, it is possible your data is corrupted, this may fix it as well.
Its internal amp is for its own subwoofer ONLY, but if you use your own amp's full-range speaker-level outputs to feed two chanels entering the sub you can tag the 'floorstanders' onto the sub's speaker terminals as speaker wire extenders. Your amp will be powering the floor units.
I'd keep the sub separate and feed it LFE only if it was mine.
Hi Ricky...saw your post re the 753 Mission tweeters. Your post goes back some months ago but I wondered if you got fixed up with replacement ones or a workaround ?? Regards Wayne [email protected]
your site says apprx 1hr however my kids were cold her in scotland also no hot water,, several hours later i googled the manual and bobs yer uncle ..it was fixed to much condinsation due to the weather being -5deg so apprx 20min to fix it was sort of easy,, so i never got an answer back from you so service not provided ,,please insert paypal payment back in to my account ..thanks george
Please advice where do I down load the link for the user manual for the projector. I lost the user manual and I forgot the password.Regards KISHAN CHAND
I'm guessing you mean one of the bass drivers (as standmount or floorstanding speakers don't have subs as such). Place your hand lightly against the driver when playing some music at normal volume, there should be some vibration (this increases the louder you play). If there's no vibration, you're probably right.
Contact Mission, who can send you a new driver, contact a Mission dealer to see how much it'll cost to go through the dealer network. I'd recommend going down the latter route if you are unsure of what to do yourself.
Just noticed you posted this in March, in which case, I hope you got it fixed (or are enjoying your new pair instead!).
