What happens when someone tries to call you ?? Does it blink on the intercom key ? Are you sure they're dialing the right extension number ? Go to your phone, dial FEATURE *0 and then press the intercom key. It'll tell you the extension number of that phone.
Other than DO NOT DISTURB (feature 85 = on, Feature #85 = off) there's nothing that would stop a phone from getting an internal call.
There is a feature built-in to the norstar system called "Set Relocation". When this feature is turned on, you can move a working extension to an unused/activated jack and the extension, features and mailbox will stay with the phone.
Have your system administrator turn the feature on, then move up to 2 phones at a time. The phone will go through 2 bootup sessions - be patient and don't unplug the phone.
Good Luck!
Depending on the type of voicemail you have It can be accomplished by calling in to the office and when the main greeting starts playing press **, the administrator mailbox number, the password and the pound key (the administrator password must be changed from 0000). Once in the mailbox press either 9 or 99 at this point you can re record the main greeting.
Go to programming of Norstar which will be F**266344 password will be 266344. Dispaly shows u terminal and extensions. press show then next display will show u capabilities. Press show then next display will show u FWD no answer.press show then next.and change the ringing as per ur requirement.
You will need to dial into the system admin of the voicemail Feature 983 the password is dependant on how many digits your extensions use. 1020000 for 3 digit and 10020000 for 4 digit, 120000 for 2 digit. go through the screens
Mailboxes, modify, scroll to password and press change. Will reset to 0000.
