Question about Whirlpool duet Washing Machines
How do I correct an f9 e1 error?
Cannot open door. Pump seems to be runnng
    Master:
  • Whirlpool Master
  • 502 Answers
F09 - Overflow condition
If the overflow contact on the pressure switch is closed for more than 60 seconds and overflow condition will occur. In an overflow condition, the door will remain locked, and the drain pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Check the drain hose and make sure it is not plugged or inked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects.
Check for Drain Pump Failure.
Check the Inlet Valve for proper shut off.
Check the Pressure switch for proper operation.
Dado
Posted on Jul 18, 2015
SOURCE:
95 Isuzu p/u fuel pump runs with key in the start position, but fuel pump does not run with key in the on position
The fuel pump only runs when the engine is being cranked or of course is running, it is shut off after about 1 second in the run only position.
Feb 09, 2017 | Isuzu Cars & Trucks
What is the corrective action for an ei f9 error?
Select power/cancel twice to cancel cycle select Drain&spinnto remove excess water
Reselect cycle and press's start pause
Jul 14, 2015 | Whirlpool duet Washing Machines
My Kitchenaid model KURD25SHBL0 dishwasher is not draining. Drain line is clear, wash cycle runs fine, and there is no obstruction to overfill sensor. Can hear pump runnng during drain cycle but no...
Usually the wiring won't affect the direction of the pump turn. It is more likely that the fins on the drain pump empellar are damaged.
May 30, 2011 | Dishwashers
Hard to start in mornings ...have to prime carb.. multi-times to get it to stay running if i'm lucky enougt to get it to keep runnng
I woud check the fuel system start with the fuel filter then have someone do a fuel system presure check to determin if your fuel pump in operating properly
Nov 27, 2009 | 1989 Mitsubishi Mighty Max
My dryer stopped working completely after runnng about 5 minutes
Check fuse on plug and power point.if this is okay could be door microswith..Good luck
Oct 24, 2009 | Dryers
Our air conditioner does not seem to be blowing any cool air...it basically just seems to be acting like a regular fan
The compressor is probably not runnng. The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 30, 2009 | Heating & Cooling
All four doors will not open. Door locks accuate with key in drivers door, trunk is only one that actually unlocks and can be opened, all other "sound" like they are unlocking but will not open. Can lock...
hello,good day,seems your have a bad contact on driver and passenger switch door actuator,maybe loose contact or mechanical defect,which not sending a signal to your central locking pump,try to remove your rear seat,look your pump,right side,driving direction,lock and unlock your car,observe your pump is working,if not,check or replaces your switch door actuator,ty
May 17, 2009 | 1984 Mercedes-Benz 190
Replaced fuel pump failure
If you can't hear the pump over the door chime, when checking, roll down the window instead of opening the door, or have someone else listen outside the vehicle! To get the relay out, spray some wd 40 or other solvent around the base... it will seep into plug and make it easier to remove. (if it's bad, it will have to come out sooner or later!!)
Did you replace the filter when you did the pump???
Feb 06, 2009 | 2000 Chevrolet Blazer
Washing Machines Logo
214 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
