The phone shows I have 3 recent voicemail messages. When I dial up the phone it rings. However I can't make calls. I can't answer calls. I can't get a dial tone.
SOURCE: How do you leaving a voicemail for your answering machine on the Vtech cordless phone?
ARE YOU WANTING TO RECORD A MESSAGE THAT CALLERS WILL HEAR OR ARE YOU WANTING TO LEAVE A MESSAGE FOR SOMEONE YOU CALLED?
SOURCE: When someone calls my phone rings 4 times then
You must turn off your internal answering machine. There should be an on and off button somewhere on the main base.
SOURCE: phone short rings every half hour, even when no
if all your 4 units ( phones ) are rringing at the same time,the problem is on the line itself.so try to contact your network's costumer care to repair it.
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
SOURCE: The Vtech CS5121-3 Cordless Phone
Hi.
Do the following system reset:
Disconnect all power adapter cables from wallsockets.
Remove all handsets from cradles.
Remove all battery from cradles.
Check the phone socket and ensure that the line is OK. Use a corded phone to test.
Connect back the Vtech phone cable.
Fit back the batteries in their handsets.
Place back handsets in their cradles.
Connect power.
The procedure above will reset the system and will re-sync handsets to cradles. If that does not work, then some of the units in the system is defective. In that case the whole system will be replaced or repaired under limited warranty terms. Contact Vtech to get your one year warranty validated. Their US phone is 1-800-595-9511 (Mon - Fri 8:00 AM - 8:00 PM Central Time). Uk contact is listed below. The last form is enquiry for global support.
See:
Contact Us ' VTech®
Contact Us - VTech UK
Contact Us - VTech
Regards.
Ginko.
