Question about Emerson EWR20V5 DVD Recorder/VHS VCR Combo - Salvage/Replacement Parts Only
Can you direct me to a source to purchase the front cover fro this model?
    Problem Solver:
  • 24 Answers
You could at salvation army stores and good will if you find one it would be a low cost replacement parts or try Craig's list.
Posted on Aug 14, 2015
6ya staff
SOURCE:
I need two of the small covers for the dials on my scope. 3-9x32 #629A
Fixya does not sell the small covers for the dials on your scope.
Jan 13, 2018 | The Optics
Replacing the back of a psp
Please consult those instructions in the following URL.
If you find this solution useful please rate it as solved.
Thank you
http://www.psp411.com/show/guide/53/0/Changing_PSP_face_plate.html
Oct 20, 2007 | Video Game Consoles & Games
Swing motor not working
These are quite easily damaged and sometimes just wear out. The cable from the motor can also be easily damaged. They are cheap and easy to replace. Just source a new one for that model online. When you receive it, turn off power to the system, take the front cover off, unscrew inside tray from cover box, slide tray out, remove the power box, get access to the motor and replace. Be sure to check which wires go where before removing and take photos or make accurate diagrams with color codes. Check that the control board functions normally before purchase though. A faulty board could cause this fault.
May 04, 2014 | LG Electronic Window Air Conditioner
Need to replace the pull cord on model 917376480
Is this the engine model? Is it Briggs and Stratton? You will need to unbolt the cover or drill out rivet's to get cover off. Once removed you will see where cord enters. Go to a hardware store and purchase bulk cord same length or slightly longer than original. Install cord and tie off in a knot like original then wind in same direction as it was, then wind assembly in tension direction of spring( a few turns) then thread cord out hole in cover, put it through handle and tie it off in knot. Then reinstall cover.This can be tricky and you may get direction backwards at first, but don't give up, you can do it. Good luck!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 01, 2013 | Craftsman Garden
The belt fell off, looked worn so purchased a new one and put it on (very tight!) Started machine, and belt new belt fell off. Pls help.
Can you confirm your model number? FAV6800A or FAV9800A?
If it's one of those models with 120VAC power cord removed from the service outlet and the front cover removed. See if you can rotate the Clutch Pulley CW the wash agitate direction and then CCW the Spin direction. The Clutch Pulley is the large pulley in the center of the washer. We are looking to see if the drive system is seized.
After the drive belt replacement was there any belt screech when you powered up the machine and selected a Wash or Spin Only Cycle?
Feb 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Where can I obtain spare anti scale filters fro the Breville Steam Generator IIN 195?
http://www.argosspares.co.uk/cgi-bin/product.pl?PID=1904605&brand=breville&model=&part=
I had to ring Breville direct as was having trouble finding them and they said as it was purchased from Argos they will have them - so went to contact argos & found this website - hope this helps
Oct 15, 2010 | Breville Irons
How hard is it to change the lamp on a sony rear projection tv. The model is a 42we655
Very easy,looking fro the front go to the right end clip off the vented cover reach in swist handle counterclockwise pull out that cover reach in lift up little handle then pull out the lamp then the opposite to put back in,hope that gets it!
May 26, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi Lamp Light Came on
Good Day, CCooke;
Lamp Number for the 55V825 Model is; UX21516.
To replace LAMP remove Front Panel outwards until the quick snap disengages. There is small cover on the left hand side, using a philips screw driver; remove. Two more screws secure lamp, use handle to remove. ALWAYS, unplug TV from A/C power source first. Good Luck, big IRISH.
Sep 03, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Emerson EWR20V5 DVD Recorder/VHS VCR Combo - Salvage/Replacement Parts Only Logo
75 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
