on my machine PE means pause
that is when I want to go out without switching the machine off or the lid is opened for a reason
check the lid sensor or switch or out of balance
PE error code is a pressure sensor code, and more than likely the sensor will need to be replaced. Try unplugging the unit for about 5 minutes and see if it will clear it out. If not, will need to replace pressure switch and hose (switch looks like a little UFO under the console, pretty easy job.
I too have the same problem with my dishwasher. Didn't know about the circuit breaker trick. Will give a try. My husband is ready to throw all our Samsung appliances in the trash. We don't recommend them at all. Re-modeled our kitchen 4 years ago and had all new Samsung appliances installed. What a mistake. In the 1st year we had 2 service calls on the dishwasher, 2 on the stove and 1 on the refrigerator. Have had many problems with the dishwasher. Have been in touch with the company but their approach is you bought it your stuck with it. Thanks for the trick to fix PE error code. I'm NOT getting it fixed. I'll use it till I can't use it anymore then go buy something else.
hi try the magnet on the right underside of your lid.mine had come loose as the lid is corroded. just tape or fix it back into place. this fixed my machine
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
hi my friend.i give u a reset code.use from it ,but first back up from important things that maybe delete after resetting.
hidden reset codeis :
*2767*2878#
