SOURCE: hinge on binoculars is too loose
there is a hinge nut at the bottom of the hinge..sometimes you have to turn of the cover or peel back the rubber to get at it
SOURCE: My Nikon binoculars show two images
must have been dropped ...have to be realigned if you want i can supply estimate 15088331232 ...larry
SOURCE: nikon compact binocular 25 years old. The hinge
Does this pair have two parallel tubes with a bridge in between?
If it does, then removing the caps at the eyepiece end of each hinge will reveal a grub screw. Tightening these will add tension to the hinge and give you the proper feel once more.
