Kitchen Ranges Logo
A
Anonymous Posted on Jul 13, 2015
Does anyone know how to set the clock and set the cooking time etc on a Leisure zenith 60 electric cooker. There are 5 buttons on the programmer
5 Related Answers
Anonymous
  • Posted on Jan 31, 2009
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
ginko
Ginko
  • 19396 Answers
  • Posted on May 03, 2009
SOURCE: my deceased mother received this as a gift and I
There are two manuals available, see below:
cook's essentials'
COOK'S ESSENTIALS®
Anonymous
  • Posted on Jul 16, 2009
SOURCE: Fisher and Paykel electric cooker (Pepper)
No, it's the first 2 buttons on the left pushed together as well as the + or - to set the right time
Anonymous
  • Posted on Oct 08, 2009
SOURCE: how do i swet the clock on my cooked - stoves ec500doa?
Hi
To set the clock you have to hold the 2 cook buttons in then use +/- buttons to set time. The cook buttons are the 2nd and 3rd buttons from the left next to alarm button. Hope this helps
Jasmin
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 21, 2011
SOURCE: Need manual for a Cook's Essentials Electric Pressure Cooker. Any suggestions?
Hello Marie,
I believe this is the manual you are looking for. It is here to view and download in pdf. I hope this is the one you were looking for, if so please rate my solution and free help. Thanks Mike
http://www.qvc.com/man/k/K97438_man.pdf?&cookie=set
Have a electric cooker model nut grb6cvk no heat from main oven everything else working
Oven heater element has died. Get the serial numbers etc off the plate on the back or the handbook, go online to appliance spares sites and see if they carry an element. If you don't know how, get a good DIYer or appliance tech to change it. You could get them to check the element for continuity first?
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 • Ovens
When i plugged my cooker in the numbers started flashing all zeros and now none of the buttons will change the screen except the cancel button. When that's pressed the screen goes blank for a second it...
I am having the same problem. Here is what the Tiger people say. I haven't tried it yet though.
* If an external power failure has occurred, but only for a short time, then there's a possibility that when the electricity has returned, all functions may work normally and the clock is working correctly.
* When a power failure lasts for a long time, and the indicator is flashing 0:00...
--> Please set the time correctly by following the instruction manual.
If the electricity has returned as in these situations below:
(If it's already past the set time, after a lengthy power failure, cooking starts immediately.)
* While cooking rice (or reheating rice).
--> Continue to do the cooking (or reheating).
* Keeping warm (or Low temp Keeping warm).
--> Continue to keep warm (or low temp Keeping warm).
1helpful
Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours.
The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat.
A small indicator light will come on below the word to tell you the cooking temperature.
thank and thanks for using fixya.
Aug 20, 2010 • Ovens
1helpful
The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
hello,
You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
7helpful
How do i swet the clock on my cooked - stoves ec500doa?
Hi
Jasmin
60helpful
2answers
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
Lofra cooker turns itself off
Hi looked on the wed could not find anyone only lofra try try them, hope this helps
163helpful
13answers
Cook's Essentials PRESSURE COOKER
I have a cook's essentials pressurer cooker 5 or 6 quart and I have lost the instructions on how to work the pressurer cooker........can anyone help me with the instructions............
Connie
Top Leisure Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
