SOURCE: Replace Switch error message
It was the emergency tag that you attached to yourself when you run (in case you fall over - the belt then stops etc). i had not connected it properly
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: I've put my Life Fitness F3 Advance folding
The safety magnet/switch is not in the correct place. Make sure it is in the correct location.
SOURCE: replacement console
Unplug unit then remove the upper console, their are 4 allen bolts holding it udder the console their is a panel held by 4 phillips head screws also remove them . Look inside the compartment and their should be two connections, disconnect them. Now pull console off its tower. Lay it upside down on a thick towel remove all phillip head screws you'll notice where the emergency stop button is connected. I have found that this connection 7 out of 10 times is causing the problem. Buy cutting the lead connector stripping the wires and soldering back on the male connection will resolve the problem. If not their is a emergency stop kit may be purchased and replace. The only other thing that may cause the problem is the function key pad itself. Try the first solution if your not good in soldiering go to a computer shop , t v shop they should be able to do this very quickly for while your at let the check the switch itself.
Testimonial: "This guy really does know his stuff. I am very pleased I was able to fix the treadmill with absolutely no expense. I simply followed the clear instructions and the machine was up and running in an hour. I would rate this expert 10/10 but actually he warrants 11! maxtreadmill yo da man !"
SOURCE: Life Fitness T5i treadmill, stops without warning
hi
try to adjust and clean speed sensor and wheel on the motor
