Question about Geneva Watches
How do I change the day, date etc on a GENEVA 7391 watch
There are 3 stems and 3 dials, there is ONLY 1 detent on main stem
    Top Expert:
  • Geneva Master
  • 10,875 Answers
Read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Posted on Jul 13, 2015
SOURCE:
How do I change the day, date, etc. It has 3 stems and 3 dials, BUT only a single detent on main stem
no idea without a make take it to place of purchase and have them show you how it works
Jul 13, 2015 | Watches
I pulled the entire crown and stem out of my Rolex President. What is involved in fixing it?
The repair for this problem may be quick and inexpensive--or somewhat more expensive. Either way, it's considered a minor repair.
The crown and stem assembly in held in a Rolex movement by a small pressure screw. When this screw is loosened, the stem can be cleanly pulled out of the movement without damaging any parts. The movement can then be removed from its case. If the screw is too loose, it is sometimes possible to pull the crown and stem out with ordinary effort. The simple fix for this would be to have a watchmaker take the back off your Rolex (requires a special wrench) and slide the stem back into the watch while loosening and re-tightening the screw. If that's it, the repair takes about 5 minutes, most of which is spent removing and replacing the watch back.
Things can get more complicated. The set stem interacts with a thin sheet metal spring / detent that helps the stem "snap" to its various set and wind positions. Sometimes, when a stem gets pulled out, the force of that can snap the delicate little finger in this watch part. Replacing this watch part will require that the movement be removed from the case and the hands and dial be removed for access to the part. Once you get to it, the part itself can easily be replaced--it's designed to be replaced without disassembling the whole watch movement--but there's considerably more effort involved than just sliding the stem back in and tightening down the screw.
May 08, 2011 | Watches
Gossip watch, has only the stem ( no other stem or buttons) watch has small dials one with day of week, one with date, I don't how to change thEM. Thank you
If you have only the stem to set your watch, then you have very few options.
I would expect your watch crown (stem) to have three positions;-
1) The home (normal position); this is used to wind the watch.
3) Fully out; this one is usually for setting the time; clockwise to advance and anticlockwise for retarding the the hands.
2) Between 1) and 3); this setting should be for setting the day of the week and the date. You will have to experiment to find which way tor turn for date and day.
Jan 21, 2011 | Watches
Perpetual Calendar Two Tone , SLL086 Watch for Men: sometimes when you take the stem out of a automati...
mcdevito75 here, Look for a small watch repair shop in your area for adjustment, don"t force the stem into any position, chances are it just needs an adjustment a watch maker can make.
May 12, 2010 | Seiko SLL086 Watch
How do I remove the stem and crown from a Skagen watch? There seems to be no set screw at the base of the stem.
First, this isn't something you should do if you are not a trained watchmaker. Many people cause more damage by trying to repair their own watch just to save a couple dollars. But the movement (insides) of a watch are very fragile and some parts can be damaged by touching them with too much force.
If you are a watchmaker you need to remember to look for the detent. That is what you need to remove the stem.
Ken
www.yellowstonewatch.com
May 13, 2010 | Watches
How do I adjust the time and date on my Timex Expedition watch
Hi, the upper of the two watch stems is turned counter clockwise (looking at the stem) until the desired function (i.e., format, date, time, chrono, timer) appears. To set that function, pull the upper stem out and turn CW to advance & CCW to go back. Once hours & minutes are set, the stem can be pushed in upon a mark to start at zero seconds. For the day of the week, turn the upper stem CCW until date appears. Pull out the stem, to detents or positions, and this will allow the day to be adjusted.
Take care
Mar 25, 2010 | Timex Expedition47761 Wristwatch
Crown will not push back in completely, it stays out in the first pull position
Sounds like the setting lever has disengaged from the stem detent. If you can remove the back off the case you may be able to reengage it. Look for either a small silver coloured pin or screw adjacent to the winding stem. If it's a pin use a sharpened match stick or similar and depress while pressing crown back in. If it's a screw - back the screw off about 1 1/2 to 2 turns, press crown back in and tighten screw again. Check operation of winder in all positions before replacing case back.
Jul 30, 2009 | Seiko Kinetic watch
When I pull out the stem 1 notch I can only change the 1 to 31 date setting. When I pull out the stem to second notch this changes the hour and minute hands. I cannot figure out how to change the 1 to 24...
Try turning the stem the opposite direction. The last watch I had with that feature required a clockwise turn to advance the time or date and a counter clockwise turn to change the day of the week.
Mar 14, 2009 | Watches
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Need to get winder out from watch so as to remove watch face
Open the back of your watch. pull the stem ( winder) out and look for a small metal piece inside that moves as you do this. There should be a little dimple on the moving piece. The piece may be on then side next to the stem, or on the movement under the movement backing plate. Tale a tweezer or something like it and push in the dimple. DO NOT PUSH HARD!!! You want to try to pull the stem out while pushing down on the dimple( it's called the detent) as lightly as you can. If you push too hard you will mess up the whole stem assemly If you still have a problem please let me know..Good Luck!!
Jul 08, 2008 | Watches
Watches Logo
805 people viewed this question
Top Geneva Watches Experts
Janelle Schoonover
Janelle Schoonover
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Geneva Watch Expert? Answer questions, earn points and help others
