No this happens everytime we use the cooker, and we used the Oven numerous times, so its been run for more than an hour more than a few times.No this happens everytime we use the cooker, and we used the Oven numerous times, so its been run for more than an hour more than a few times.
AnonymousJan 07, 2008
I have a Baumatic oven and the same problem - a petrol type smell when it's running.
I can't find any solution online, or even mention of this problem.I have a Baumatic oven and the same problem - a petrol type smell when it's running.
AnonymousJan 04, 2009
the fan on my zanussi makes a noise the fan on my zanussi makes a noise
You can't post conmments that contain an email address.
if this is gas it calls the induced draft motor to come on for 15 to 20 seconds to clear any residual gas before beginning the ignition process begins. Very normal and a safety feature.
There may be a problem with the cooling or extraction fan on the oven. All Neff appliances come with a two year manufacturers warranty, so I would advise you call them out on 0844 892 8999. If you attempt a repair yourself, you could invalidate the warranty.
All the best.
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Plz rate my solution.
Thanks.
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
