I have had a bent rim replaced, and still have not been able to get rid off the shake. Used new tire on a replacement rim I got a few weeks after buying the car, still shakes. Used a different tire on a different rim, still shakes. But only get the shake from the replacement rim and the non matching rim I borrowed from a friend who drives an 2007 Sonata. But the shake only comes from the spot with the new wheel. I even had all of the tires road force balanced. And it shakes no matter where I put it, front, rear, left, or right side. I'm totally at a loss.
You probable damaged the suspension if u bent the rim--you could have damaged the hub {wheel bearing} ball joint ,tie rod,c/v axle,shock/strut even damage to brake system
Testimonial: "Had bent rim I didnt notice until high speed after purchase. Replaced the rim. Had four new tires upon purchase as well. Even tried a different tire on the replaced rim. Still shakes. And it follows the rim and tire combo always. Even up to front of car...."
Obviously there is something wrong with either the tire or rim. Try a different tire and rim. Make sure it is the correct rim and tire that is supposed to be on your car only.
You don`t say if you had the wheel/tire balanced. you could have damaged the CV joint on that side causing a binding in the bearing.
I have had the wheels and tires balanced at my local shop and I got so frustrated I found a shop and hour away with road force balancing.
Still no help.
