Take a look at these two links that each offer some methods you can try. I hope it helps.
How to unlock android tablet after forgetting pattern lock
How To Unlock My Tablet if Forgot the Unlock Pattern
I post on behalf of HP.
SOURCE: forgot the pattern to my coby tablet mid8020 4gb
Unfortunately to protect the integrity of this site, I can't give you information that may be used to access someone's tablet.
SOURCE: I forgot my unlock pattern to my tablet
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
SOURCE: I need to reset my tablet to set a new pattern to
You'll need to do a factory reset:
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
SOURCE: Model:v705-s tablet pattern lock.so unlock the
If you cannot unlock the tablet, look up the way to do a hard reset. You will lose all data, but it's one of your only options.
Usually the following method works:
1. Turn the tablet off.
2. Hold the volume down button.
3. Hold the power button.
This should boot you into your devices restore/update screen. If that combination does not work, volume up + power should.
4. Navigate to the wipe data/factory reset.
5. Wait for it to reload, and you're done.
