Maytag MHW6000XW - MaximaTM High-Efficiency Front Load Washer Logo
Kip Nielson Posted on Jul 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MHW6000XW LIST OF ERROR CODES AND WHAT THEY MEAN
IM GETTING A E02 AND F01 ERROR CODE
fsean Kil
Level 2:
New Friend:
  • Expert 111 Answers
  • Posted on Jul 24, 2015
fsean Kil
Expert
Level 2:
New Friend:
Answers
111
Questions
0
Helped
29524
Points
286
F20 water only problem insufficient water supply open both hot and cold unclog hoses
F21 Drain problem clogged,frozen kinked
SUD excess sud using non he detergent or to much detergent
F22 front door lock door not closed properly
For these select poepwer/cancel twice to cancel cycle
Other f codes select power/cancel twice select drain& spin if youhave excess water
2 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jul 23, 2008
SOURCE: I have a maytag EpicZ,
I just had this problem and I kept the washing machine on and flashing f01 and I pulled the power cord out of the outlet while it was still on and it reset it and I could start washing immediately.
some1cares_m
Jorgie the appliance guy
  • 5639 Answers
  • Posted on Jun 15, 2015
SOURCE: My may tag washer has codes F06 & E02 , what does this mean?
I beleive e02 is something to do with ur drain pump set up clogged or damaged water pump and hoses
I have a whirlpool duet front load washer with error code E02 F01.
According to https://www.justanswer.com/appliance/7w4q8-f01-e02-error-code-showing-whirlpool-front.html, it indicates that the controller isn't getting readings from drum tachometer. Could possibly be loose wire. Replacement parts said to be $200, so may not be worth buying.
you might be able to sell to someone willing to diagnose & fix.
E02 flashing
Whirlpool breadmaker e02 error Questions & Answers - Fixya
www.fixya.com > Forum > Tags > breadmaker e02 error
Ask your Whirlpool breadmaker e02 error questions. Get free ... I am getting F01 andE02 flashing errors and the machine will not go into spin cycle . How bad is ...
1helpful
Error code E02 and F01.
Replace the motor control board. The machine cannot tell the speed any longer. These boards are expensive and even much more time consuming to think you can repair the board. Call your local parts place and ask them if they can have the board tested, if you want to .
I have error code f01 and e02 showing up on my whirlpool duet washing machine what does this mean'?
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#ixzz3PsUurTNH
Washer will not run
f06 OR e02 error code means you have an interface communication error. the main control board isn't communicating with the front interface control board. if you pull the washer out and remove the 3 screws coming in from the back of the top panel. the top panel will pull straight back, up, and off. check all the wire connections between the two control board and make sure they are all secure. if everything looks good, then the interface control board may need to be replaced.
f01 e02 means that your motor control board is not reading the tachometer on your motor when it tries to turn the motor. it thinks that the motor is struggling. open the door and turn the basket to make sure it spins freely.
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
