Amana  Portable Air Conditioner Logo
A
Anonymous Posted on Jul 10, 2015
How do I replace the fan? - Amana Portable Air Conditioner
Claude Kayser
Level 3:
Top Expert:
  • Amana Master 9,098 Answers
  • Posted on Jul 10, 2015
Claude Kayser
Amana Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067236
Points
28436
Free Amana Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Amana
Products 1 - 10 of 10 - Amana Air Conditioner 18M23TB. Amana Room Air Conditioner Use And Care Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade .
1helpful
Cannon ir 3025 photocopier displays error code 805-000.
E805
There is a fan error.
0000
Failure in heat exhaust fan (front) (FM2)
When lock signal is detected for 5 sec while the fan is stopped.
- Replace the heat exhaust fan (front) - Replace DC controller PCB
0001
Failure in rotation of heat exhaust fan (front) (FM2)
When lock signal failed to be detected for 5 sec while the fan is driven.
0002
Failure in heat exhaust fan (rear) (FM1)
- Replace the heat exhaust fan (rear) - Replace DC controller PCB
0003
Failure in rotation of heat exhaust fan (rear) (FM1)
there are 2 fame in the right door if you just look on the right door you will see 2 square vents
get in there and remove the fans and clean them out with canned air and apply a small amount of oil in the center then flick the fan to make sure it spins softly
reinstall and try it should fix the problem but please go ahead and order a new fan the part number is on the fan itself in the sticker it will say FK2-????-????
2004 grand marquis fan quit working..replaced fan but still wont work
is this the blower motor fan for you heating and A/C or the cooling fan cooling fans have a relay blower fans are fused but controlled from switches inside as well as fuses
1helpful
My radiator fan is not working
For radiator replacement procedure and radiator problem troubleshooting. I suggest you to click the link below and follow the detailed procedure :-----
How to Replace Engine cooling Fan on car? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
Engine makes noise and Cooling Fan belt Breaks? http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
Cooling fan relays location? http://technoanswers.blogspot.in/2012/02/cooling-fan-relays-location-on-1998.html----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
How to replace radiator Cooling Fan?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
cooling fan not working http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html----------- Fuel pump relay and cooling fan relay troubleshooting? http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
How to replace Radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
HOW TO REPLACE AN UPPER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
HOW TO REPLACE A LOWER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
How to replace Radiator on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-acura-car.html
How to flush cars radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-flush-cars-radiator.html
HOW TO PRESSURE TEST A RADIATOR AND CAP
http://schematicsdiagram.blogspot.com/2011/07/how-to-pressure-test-radiator-and-cap.html
HOW TO REPLACE A RADIATOR
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator.html
HOW TO REPLACE A RADIATOR SUPPORT
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator-support.html
This details will help.
Thanks.
I need a replacement motor for a NuTone Model LS-80SE exhaust fan but can't find one.
Home depot usually has a good selection of replacement fans. They usually are a fan on a mounting plate, not just the fan motor itself. Sometimes you have to purchase the entire fan unit just to get the fan motor plate inside for a replacement part.
1helpful
3answers
Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
3helpful
3answers
57.70 error for hp colorlaserjet 9500n
this is the fuser fan error replace them ur problem will be resolved
The fan is very noisy
The post begs for the obvious answer: Replace the fan.
Now to be more polite, first you need to identify the failing fan and replace it.
A desktop system can have several fans. Case/processor fan (you can test to see if this is the effected fan by unplugging it for a minute or two from the motherboard (a couple minutes will not hurt the system).
The video card may have a fan on it (Often on the underside if a mini tower) Some video card fans can be easily removed but finding replacement fans can be a challenge. Normally if a video card fan fails, replace the video card.
Most often, the failing fan is in the power supply unit or PSU. If you are handy with electrical components, you can remove the PSU, remove the fan and replace it. If you are not handy electrically, replace the PSU.
Higher end system may have card cage fans to help cool hard drive/expansion cards and others have fans specifically to coll hard drives.
Most manufacturers have spare parts where you can buy parts or you can use google to find specific replacement parts or fan suppliers.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
