Wilson Shieh Posted on Jul 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba copiere206l series error code F101 sub code 5
kasun fernando
Level 2:
Wolfpack:
An expert that has 5 followers.
  • Toshiba Expert 253 Answers
  • Posted on Jun 26, 2016
kasun fernando
Toshiba Expert
Level 2:
Wolfpack:
Answers
253
Questions
Helped
107074
Points
354
Partition mount error
If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check
that each Key Status is "OK".
Toshiba Estudio 4508A has an error code of F101. How do I fix it please?
Question edited for clarity
https://www.copytechnet.com/forums/toshiba/142847-toshiba-estudio-3508a-error-f101-1-a.html
HDD, SYS board, Setting 1. Turn the power of the equipment OFF and check the
connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform HS-73 Firmware Assist mode -> Key
Backup/Restore and check that each Key Status is
"OK".
- If not, recover the key (press [Key] and select the
menu, and then press [Execute]).
3. If the error still persists after step 2, perform the
following.
- Perform HS-73 Firmware Assist mode -> Format
HDD, and then install "System software" (HS-49
Firmware Update mode -> SYSTEM SOFTWARE
(HD Data)).
Notes:
The following items will be deleted by HS-73
Firmware Assist mode -> Format HDD.
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If F101_1 occurs with secure HDD or the error
persists after performing step 3, perform step 3 after
performing HS-74 HDD Assist mode -> Revert
Factory Initial Status HDD.
4. If the error persists even after step 3, replace the HDD.
5. If the error persists even after step 4, replace the HDD
harness.
https://www.google.com/search?q=Toshiba+estudio+4508A+has+an+error+code+of+F101
Toshiba studio 257 how to fix error code F101 sub code 4 how do i fix this error ? For what reason this error accures
This is a Hard drive failure. The hard drive would need to be replaced and firmware installed on it to resolve your problem.
F101 code toshiba 3540c copier
the hard drive contents have been corrupted. Thread studio 4555c error f101 sub code 1 good luck with that one. i suggest you start reading the service manual but the link provides you with the idea.
I need to reset the f101 code on a toshiba 477s studio as I enter service mode
F101 is HDD related error...
If HDD no issue, format HDD update firmware will solve
Toshiba e studio 2051c showing F101 call for service 5 ERROR . How to fix it?
DH, Toshiba e studio 2051c showing F101, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Toshiba 256se 101 4 error
Toshiba studio 2051c Troubleshooting Manual
How to remove f101 error code
hi
The hard drive contents have been corrupted. Thread studio 4555c error f101 sub code 1 good luck with that one. i suggest you start reading the service manual but the link provides you with the idea.
1helpful
3answers
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
