SOURCE: i cleaned my great lakes hot tub and there is no
Sounds like you have an air lock. Loosen the union at the pump, turn jets on, air will escape and then tighten back up.
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
SOURCE: Error code reads
'Sn' is a general error message relating to the temperature sensors.
Assuming that you have a Balboa spa pack (M7 version), turn off the power and remove the spa pack cover, you'll find two temperature sensors mounted in the top of the heater tube one at each end. Follow the wiring from the sensor to the plug(s) on the PCB and check that the connections are good, they have a habit of devekoping a poor connection.
If you have a multimeter you could also check the resistance of the two sensors. They should both be the same. If they aren't the same you'll probably have to replace them.
One final thing just to check... Ensure that there are no blockages within the heater. Unless you have service/gate valves you will have to drain the hot tub, unscrew the unions and check inside the heater for debris within the heater assembly.
If you're from the UK I may be able to help regarding parts etc.
Kind Regards,
Ian.
http://hottub.synthasite.com
