If it is the check engine light, Yellow light that looks like a engine, or may say "Check engine", Yes, it is safe to drive until you can get it checked. As long as the vehicle is driving normal. If the light starts flashing, DO NOT DRIVE it. A flashing check engine light means a misfire and could cause a fire due to raw fuel going down the exhaust into the cat converters.
Rachell, try checking your tire pressure. Look closely @ the light your describing, its actually an outline of a tire. One or more of your tires are low on air. Air pressure sould be around 40-45 psi The light sould clear after a short drive. Hope that helps Greg.
Depending on which light is flashing will determine whats wrong, normally thee are three lights that flash one is yellow check engine light, when it flashes it means a misfire and catastrophic catalytic converter failure. Red oil light means your low on oil and if it does not have a gage you may have damaged the engine and then there is several others like air bag warning light this would be caused by a defective clock spring, or a malfunction in the computer system. Your best bet is call your local dealer and describe to them your problem and tell them what lights are flashing they can determine weather you should drive it or have it towed in for repairs. Remember FLASHING RED OR Yellow light means imminent failure of expensive engine parts.
it means its due for service. If u wanna get rid of it without servicing the vehicle then as you start the car simultaneously push the ODOMETER reset button on the dash and it will wipe it. This will however just delay the point your car needs servicing.
