Kyocera Hydro Boost Mobile Logo
j
julia manus Posted on Jul 08, 2015
How do i get microphone back on my text keyboard
Aunt Nutmeg
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Jul 11, 2015
Aunt Nutmeg
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
4447
Points
39
Julia,
Try this: go to Settings > Language & Input, then tap on the gear icon to the right of "Google Keyboard".
Tap on "Preferences", then make sure the box is checked which is right of "Voice Input Key".
After that your microphone icon should be back on the keyboard. :) Hope this helps!
How do you use the microphone to speak text?
software needs to be purchased and installed on your
device, if it is not already there.
How do I set up voice to text on Samsung galaxy S8+
There is a tiny microphone icon on the QWERTY keyboard, touch it and wait for input to come up and talk.
On messages I caused the bottom keyboard to be mobile and small need to get it back original
Samsung Galaxy S GTI-9000: Accidentally caused the Floating Keyboard to appear, How to get it back to normal mode:
Hello. Don't worry you're not the only one that's done this before. It's really easy to fix
On the Samsung Keyboard there's a key on the left next to the space bar and "," comma key, the microphone.. inside that key above the microphone is 2 dots and a gear, that's a symbol for Settings.. We want to go there
1. To get to the options in grey above the Qwerty keys: Hold finger down on key: so for this one we're going to hold down on the microphone key..
2. After menu pops up, look to the right side of that menu bubble for the keyboard icon
3. Lift off finger and tap the keyboard icon
Success!
1helpful
I have a new Alcatel one touch, Fierce 2 cell phone. I bought it last week. When I first used it, the phone had a microphone icon in the texting area. Now it's gone. How do I get it back so I can
If you good down the comma button the setting menu for the keyboard should pop up. If it does not it may not have the standard keyboard installed especially since you may have added an emoji keyboard. You can select the manufacturer default from the same menu by going to phone settings then keyboard. The last option would be to go to the Google playstore and download the keyboard put out by google. To do this do a search for google keyboard make sure that google is listed as the developer. Once downloaded and installed choose the keyboard from the settings, input, keyboard menu.
How do I fix my talk to text feature?
The "Cannot Connect" message indicates that your device is not able to access the internet, either through your cellular service provider (ie. Verizon, AT&T, T-Mobile, etc.) or through a Wi-Fi router if you happened to be connected to one. You must have a data plan in order to gain access through your provider. Also check the settings on your phone to make sure you are connecting to a Wi-Fi if you happen to have access to one at home or work place.
How to text by using voice
their should be a lil microphone button to push when on keyboard....... and if that doesnt work go to settings, keyborard, and then click on default google voice typing if u hae an andriod phone. hope this helps
Mar 16, 2013 • Cell Phones
How do I setup speech to text on my sanding captive cell phone
Go into my text messages and use the android keyboard, there is a little microphone at the bottom of the keyboard to the left of the spacebar. It allows you to talk into the phone and it converts your speech to text.
You should have google voice installed.
You should also go into the settings on the phone, clicked on text to speech, then clicked on "install voice data."
Hope this helps.
Recently purchased the Shure Beta58A microphone for my son to use with his Yamaha MO8 keyboard. We cannot determine where to connect the mic into on the back of the keyboard. I have a feeling that the...
I cannot say I'm certain of the keyboard model in question. However, one does not usually plug a microphone into a keyboard. Does it have built-in speakers?
BUT, assuming it is made to accept a microphone, there should be a "mic in" or "microphone input" jack on the keyboard. DO NOT plug into the MIDI jacks (if you find the right adapters). MIDI is a control protocol so keyboards and sound modules can "talk" to each other and one keyboard player can control multiple sounds from one keyboard.
Top Kyocera Cell Phones Experts
Jim LeVerso - IT...
Jim LeVerso - IT...
john h
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
