The printer is in good working order if it displays the messages READY, BUSY, or POWER SAVER. Try the suggestions below if the beeping sounds persists.
The printer is indicating a "hardware failure" condition if it beeps THREE times, followed by a pause. The printer's display panel needs to display the precise fault message. Determine what the error message is trying to tell you and take the necessary action. Power off the printer and let it wait for a minute before turning it back on if you are unable to determine the precise fault situation from the panel. The printer will probably need repair if this issue persists. For more help, please get in touch with local authorised service providers or Lexmark Technical Support.
The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
Hi, What is the error light
Step one: Identify the specific printing problemIf
your All-in-One won't print, first you need to identify the specific
issue or symptom. What exactly happens when you try to print? Do you
see an error message or do the lights on the printer start blinking
(flashing)? Does nothing happen at all? Follow these steps to identify
your unique printing issue before troubleshooting. If you can identify a symptom based one of these methods, make a note of the symptom, and then continue to the next step.
Method one: Look for blinking lightsLook
for any blinking lights on the front or top of the All-in-One.
Sometimes just the power button can blink, or a small indicator light
on the printer can blink, or a combination of buttons can blink all at
once.
Example indicator lights on the printerAttention lightsWireless indicator lightCartridge lightsError LightsExample blinking lights patterns Method two: Look for error messagesPrinting
problems are usually accompanied by an error message of some sort,
usually on the control panel display (if your All-in-One has one), or
on your computer monitor. Check both places for specific error
messages. Error messages might or
might not be accompanied by an icon representing the error. Following
are some examples of error messages you might see on your computer
screen or control panel display.
'Printer is Offline
'Align Cartridges
'E
' (error condition)
'Document(s) pending
' (Roll your mouse over the product icon in the lower-right corner of the computer screen.)
there are two cartridge one is the ink cartridge which can be found on the left side of the printer (in front)and the other one is the head cartridge that can be found on the right side if you will open the printer cover that is the carriage check it if the flip cover is lock properly then try to reinsert the head cartridge..
What is the message that should be display in the LCD display? The Alert light signals a problem the printer thinks it has and usually display amessage in the LCD display to help a user determine what may or may not need repair or service.
