Tablets & eReaders Logo
A
Anonymous Posted on Jul 08, 2015
How do i hard reset my lg uk 410 tablet - LG Tablets & eReaders
rythot
Level 2:
Sergeant:
  • Expert 291 Answers
  • Posted on Jul 08, 2015
rythot
Expert
Level 2:
Sergeant:
Answers
291
Questions
Helped
71329
Points
754
Settings --> Resent menu 9.
Reset settings menu--> Master Reset options YES --> enter your 4 digit security code. The default code was 0000 unless you changed it. This will delete the phone entries. Security menu allows changing security code. You did backup anything you wanted to save, right? Note that customer service may remotely repair some phone problems.
http://www.hard-reset.com/lg-410g-hard-reset.html
1helpful
How can I reboot my Samsung galaxy 2 tablet 10inch. it keeps dropping pages or freezing when i'm playing a game . please help if you can ....Thank You ...
1.Make sure device is completely powered off. 2.Press and Hold The Power and volume down button at the same time. 4.Select factory data reset in recovery menu. 6.Reboot System Now and you're finished!18 Mar 2013
How to Hard Reset Samsung Galaxy Tab 2 10.1 Android 4.0 Remove ...
https://www.youtube.com/watch?v=EeWiML00i9E https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=reboot+Samsung+galaxy+2+tablet+10inch
How to hard factory reset an apple ipad, don't have passcode
Reset iPad: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears. Reset iPadsettings.16 Apr 2013
Apple iPad hard reset
www.hard-reset.com/apple-ipad-hard-reset.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=hard%20reset%20an%20apple%20ipad
How can I do a factory reset on my nextbook 7
Simple video on how to hard reset Nextbook Android Tablet. Power off device, select volume up and then power, hold power for 5-7 seconds and let go without releasing volume up. When u get the android menu scroll down to wipe data navigating with the volume buttons and then to wipe data.20 Aug 2013
Nextbook Android Tablet Hard Reset - YouTube
https://www.youtube.com/watch?v=TM-Ir-stVL8 https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=How+can+I+do+a+factory+reset+on+my+nextbook+7
2answers
When I reset my lg vslate tablet now the touch screen doesnt work
Attach to power charger. Try hard shut down then try reboot all while connected. Then at that point you should see your keyboard again once o/s is back up.
How do I do a hard reset on a 7 inch LG AT&T g tablet
TO RESET MINE I FOUND A VIDEO SAID TO PUSH THE VOLUME BUTTON AND OFF /ON BUTTONS AT THE SAME TIME ..THEN YOU GET A RESET MENU ON THE SCREEN ..JUST TAP IT AND IT STARTS ALL OVER ..TAKES A LITTLE WHILE BUT MINE SEEMS TO WORK FINE NOW
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
How do i reset my tabeo?
If any problem arises in computer, we are habituated to format the PC. The same applies to laptops also. But when there is any problem in your tablet PC, there is no other option except factory resetting. It is similar to formatting. When your tablet gets infected with some virus, or when you got it locked accidentally, or if you feel that your tablet PC is running slow, you might have to go for hard resetting or factory resetting. You might opt for hard resetting due to various reasons, but the procedure of resetting is similar in most of the tablets. First of all, when you are going for hard resetting of the tablet, you have to check whether the manufacturer of your tablet has mentioned any special procedure for it.
In most of the cases, the procedure will be same on all Android tablet, unless specified. You can check the official website of your tablet manufacturer or can also go through the manual book given at the time of purchase of the tablet. If nothing is specified, you can carry out the generalized process. For factory resetting your Tabeo tablet, you have to go to 'settings' page. In this menu, you can find an option for 'hard reset'. If you click or tap this menu, you can get a new options where you will find option for hard reset. In this list, you can also find the option for hard resetting. If you select that option, the tablet will ask for confirmation.
Once you confirm, the tablet will perform factory resetting. Factory reset or hard reset will wipe of the data present on your tablet. So, it is very much necessary that you take back up of the data present on the tablet before heading for resetting. It is a good idea to keep the back up of all the files regularly so that you can go for hard resetting at any time, if the tablet gives any problem.
Lg v901 hard reset
Hi Amer,
There is simple way to reset it
First Switch off Your tab & remove the Back cover.
there you can find a Small round Reset button...!!
hope u got it :-)
here u can see it
and press it ....
you can use something pointed tool
maybe a Ball-Pen (its best)
when u press & hold it... your tab will reset
if it not, then try to press it with holding the VOLUME DOWN button ;-)
that's it
OK
Content fulfilled by another user
This means that the user somehow requested a book from the server that had already been downloaded. This error is also known as the "410 gone" error, since the generic response from the server of 410 indicates that the request is no longer valid.
Top LG Tablets & eReaders Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
