Spins freely, washes fine, just on spin the noise. Purchased in 2008 with no extended warranty.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Only at high speed. I have a video but not sure how to share with you. I have checked the whole interior and see nothing
It is not leaking- I pulled it out and took off the back.
Mine does that same thing. Took the whole thing apart found a couple pennies and it still did it, then replaced the pump because it started to leak - still makes the noise - any ideas??
