I was on a app and my iphone screen seemed to magnify itself now its sooooooooooooooooooooooo annoying to use!!!!dont know how to get it back to normal
STUPID SOLUTIONNNNNNNNNNNNNNNNNNNNNN
Doesn't work, what an idiot. Just tap twice with your 3 fingers & your zoomed screen'll get back 2 normal
This person is correct. I tried everything and then felt like a fool when I read the above comment and the phone unzoomed instantly. Thank you Karen, DC
Same thing happened to me. The 3 finger thing WORKS! I was ready to find an ATT store nearby. I'd have felt like such an idiot!
Me too! Thanks Karen!
thank you for your help!
This might help....
ZoomMany
iPhone applications let you zoom in and out specific elements. For
example, you can double-tap or use the pinch gesture to expand webpage
columns in Safari. Zoom is a special accessibility feature that lets
you magnify the entire screen of any application you’re using to help
you see what’s on the display.
Turn Zoom on or off: In Settings, choose General > Accessibility > Zoom and tap the Zoom On/Off switch.
NOTE: You cannot use VoiceOver and Zoom at the same time.
Zoom in or out: Double-tap
the screen with three fingers. By default, the screen is magnified by
200 percent. If you manually change the magnification (by using the
tap-and-drag gesture, described below), iPhone automatically returns to
that magnification when you zoom in by double-tapping with three
fingers.
Increase magnification: With three fingers,
tap and drag toward the top of the screen (to increase magnification)
or toward the bottom of the screen (to decrease magnification). The
tap-and-drag gesture is similar to a double-tap, except you don’t lift
your fingers on the second tap—instead, drag your fingers on the
screen. Once you start dragging, you can drag with a single finger.
For best results using three-finger gestures, relax and let your fingers touch the screen naturally.
Move around the screen: When
zoomed in, drag or flick the screen with three fingers. Once you start
dragging, you can drag with a single finger so that you can see more of
the screen. Hold a single finger near the edge of the display to pan to
that side of the screen image. Move your finger closer to the edge to
pan more quickly. When you open a new screen, Zoom always goes to the
top-middle of the screen.
