Televison & Video Logo
Cynthia Unruh Posted on Jul 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forgot code for parental lock on my RCA F32668 32" tv, please help. Thanks
David Payne
Level 3:
Top Expert:
  • RCA Master 14,162 Answers
  • Posted on Jul 07, 2015
David Payne
RCA Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998293
Points
455836
RCA TV Parental Reset Code: First select parental control from the menu. You will be asked to enter your password. Press and hold the "volume +" and "channel +" buttons on your television (not the remote) for 8 seconds. You will see a message that the parental controls have been unlocked.
How To Unlock Your TV Parental Control Password
Level 3:
Top Expert:
  • RCA Master 76,851 Answers
RCA Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005687
Points
237762
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
5 Related Answers
Anonymous
  • 1067 Answers
  • Posted on Jan 27, 2008
SOURCE: RCA -parental control
Unplug unit. Hold power button in and plug unit in while holding power button till it beeps or flashes. This will erase eveything and you'll have to start from begining. good luck. This doesn't always work and the unit may have to be reset from the factory
Anonymous
  • 188 Answers
  • Posted on Sep 16, 2008
SOURCE: deactivate parental control on my rca tv
Here is the download for the model you listed. I on page 36 is how to reset the code. I'd keep the manual out of your kids hands. ;-)).
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Anonymous
  • 84 Answers
  • Posted on Jun 26, 2009
SOURCE: I Forgot my parental control code!!
to reset it just unplug it. the memory only works when there is power to it.
Anonymous
  • 3130 Answers
  • Posted on Jul 06, 2009
SOURCE: my rca tv has locked the parental code and dont
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Anonymous
  • Posted on Jan 16, 2010
SOURCE: Parental Lock Code
If you forget your password you can reset it. Make sure the
TV is off. Simultaneously press and hold VOL< on the TV’s front
panel and CLEAR on the remote for approximately 5 seconds. Enter
a new password next time you access the PARENTAL CONTROL
menu.
Rca lcd tv model l26d10 forgot parental lock code master code was 0000
If you forget your password, turn off the TV.
Simultaneously press and hold VOL v on the side panel and
CLEAR on the remote for 10 seconds. Next time you enter the
Parental control menu enter a new password.
Recently purchased a rca tv model F35317, parental code from previous owener locked need to bypass
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
Hope this helps you out. Thanks
Problem with RCA F27440 parental control. Forgot the password.
From the manual...
"If you forget your password, simultaneously press and hold MENU on the television and volume down on the remote for 3 seconds...Nothing appears on the screen, Parental Controls simply unlock and you can re-enter a password via Lock Parental Controls."
Hope this helps.
I forgot the password for unlock the parental control
Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
2helpful
3helpful
2answers
Need help unlocking the tv parental code
Enter 8888 as the password & then push ok.
Reseting parental locks
Check the info from this link to unblock the channels.
1helpful
Parental Control Code?
if you forgot your password you can reset it ,turn tv off press and hold vol< on tv and clear on the remote for 5 sec.,enter a new password next time you access the parental control menu.
Tv problems
Valerie,
Thompson/RCA states: "If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Let me know if that does the trick getting it unlocked..
Bill
3answers
I dont know the parental code and my color is messed up how do i fix it.
OR TRY THIS..
Bill
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
