Lee Fears Posted on Jul 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just receive this technics su-g91 amplifier and i was trying to hook up my surrond sound but only my center spreakers are working..what am im doin wrong
johnny rebel
Level 3:
Top Expert:
  • Master 10,875 Answers
  • Posted on Jul 05, 2015
 johnny rebel
Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2942309
Points
47944
Did you hook up both rear speakers?in the right spots?,if not they wont work,do you have the speaker buttons pushed in?? TECHNICS SU G91 INTERGRATED AMPLIFIER 130W CHANNEL
Testimonial: "Yes I did that...when I press the Dolby pro logic button..that's when I hear sound in the center speakers..."
David Payne
Level 3:
Top Expert:
  • Audio Player... Master 14,162 Answers
David Payne
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998498
Points
455836
Testimonial: "Thanks..but that really didn't help because I know how to hook up my speakers I'm just trying to figure out why the sound isn't coming out my other speakers"
User manual for technics su-g91
Check the Technics website, or Panasonic, as Technics was made by Panasonic.
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
2answers
I have no sound in teh left channel , could be an integrated ?
Hey, The model of the amplifier is SU-G91 Technics.....If you could help......Thank you.
1helpful
3answers
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
2answers
Su-g91
Have you checked the fuse in the unit?
2answers
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
3helpful
4answers
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
 Grubhead
Grubhead
SmartAviator
SmartAviator
