Honda 2012 Civic EX Logo
edandmartha salas Posted on Jul 05, 2015
How to remove rear bumper - Honda 2012 Civic EX
Leslin Waker
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 06, 2015
Leslin Waker
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
3656
Points
15
Https://www.youtube.com/watch?v=sbsjeh8eB9A The video teaches.
How to replace 2008 Kia Sedona rear bumper cover
2008 Kia Sedona Bumper Covers
CarParts.com https://www.carparts.com > ... > 2008 > Bumper Cover
Get the best deals on an aftermarket 2008 Kia Sedona Bumper Cover. Lifetime Replacement Guarantee. Free 60-Day Returns. Order today!
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 70px;"> Rating: 4.8 Ā· ā€Ž10 votes Ā· ā€ŽUS$101.99 to US$139.99
NEW Rear Bumper Cover for 2006-2014 Kia Sedona ...
Bumpers That Deliver https://bumpersthatdeliver.com > new-rear-bumper-co...
This replacement Rear Bumper Cover will help restore your vehicle's aesthetic value if you need to replace a scratched, dinged, or collision-damaged Rear Bumper ...
US$240.99
Rear Bumper Cover Repair procedures
Kia Sedona manuals https://www.kisedona.com > rear_bumper_cover_repa...
Take care not to bend or scratch the trim and panels. 1. Remove the rear combination lamp cover (A) using a screwdriver or remover.
1helpful
2answers
2008 ford escape. removal of rear bumper cover
Pop the Hatchback open and remove the connectors
from the top of the bumper cover.
Optional Step: Using a Floor Jack, raise both sides
of the car in the back, supporting both sides with
jack stands, and remove the rear wheels.
Using Torx Bits, remove the inner rear wheel well
lining.
Get behind the rear wheel well and loosen the bolts
holding the bumper brackets on. They're pretty
difficult to find and remove. Be Patient. Do the
same to the other side.
Remove the rear bumper cover by pulling the cover
outward from the part nearest the wheel on both
sides. Once removed, take off the 2 black mounting
brackets from the bumper cover.
Good Luck
How to remove honda brio rear bumper
When it comes to remove Honda Brio rear bumper, like 2021 Honda Brio, first, use professional tools to unscrew all the screws in order. After disassembling all the screws of the rear bumper, hold the side of the rear bumper with your hand, and gently break it out to separate the two sides from the car body. Finally, we can remove the middle card from the guide groove.
How to remove bumper
1. Remove rear combination light assembly. A. Remove two mounting screws. B. Disconnect electrical connector from rear side of light assembly.
2. Remove bumper assembly. A. Remove four fasteners and four retaining screws from top of bumper assembly. B. Remove mud flap from bumper assembly. C. Remove two screws from bottom of bumper assembly. D. Remove two screws from side of bumper assembly. E. Remove four bumper mounting bolts from under of vehicle.
3. Install rear bumper in reverse order of removal.
4helpful
2answers
How to remove rear bumper 1999 blazer
Hi there:
Check this Removal Procedure...
1. Remove the rear bumper step pads.
2. Remove the license plate lamps.
3. Remove the nuts and the bolts that retain the rear bumper impact bar to the bumper bracket.
4. Remove the rear bumper impact bar from the vehicle.
Installation Procedure
Notice: Refer to Fastener Notice in Service Precautions.
1. Install the rear bumper impact bar to the vehicle as follows:
1.1. Position the bumper impact bar on the bumper brackets so that the holes in the impact bar are aligned with the bracket holes.
1.2. Install 2 bolt plates and 4 nuts on top of the impact bar.
1.3. Install 2 bolt and nuts through the bottom of the impact bar. Tighten the rear bumper impact bar nuts to 90 N.m (66 lb ft).
2. Install the license plate lamps.
3. Install the rear bumper step pads.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
How to remove the rear bumper cover on a pontiac 2004 grand prix
  1. Open the trunk.
  2. Remove the rear compartment sill plate. (Trim round the back edge of the trunk)
  3. Pull the left and right compartment side trim panels down to access the fascia bolts and nuts.
  4. Remove the tail lamps.
  5. Remove the fascia bolts and nuts from the rear bumper fascia 1 nut 1 bolt on each side near tail lights.
  6. Remove the push-in retainers from the top edge of the fascia.(4 plastic circles, pull up on center of cirle with screwdriver
  7. Raise and support the vehicle.
  8. From underneath Remove the push-in retainers from the rear bumper fascia (one on each side I think)
  9. Remove the fascia bolts from the rear bumper fascia. on on each side from, up where the facia connects to the quater panel)
  10. Remove the rear bumper fascia from the vehicle
3helpful
2answers
How do I remove the back bumper from a 2006 hyundai tuscon?
take help of the following steps to remove rear bumper on ur tucson.
Open the trunk of your vehicle.
  1. Unscrew all the screws on the inside plastic trim that covers your bumper to trunk connection.
  2. Pry the plastic piece out with a flathead screwdriver. You will expose the bolts that attach the rear bumper to the trunk.
  3. Unscrew the bolts connecting to the inside of your rear bumper. There should be four bolts.
  4. Unscrew the two to four screws connecting to your bumper from the inside of the rear wheel tire wells. These screws are on the area of the tire well that is closet to the bumper.
  5. Slide under the rear of your car. Use a flathead screwdriver to pop the plastic rivets out of place along the underside of the rear bumper. There should be four to six rivets.
  6. Squat behind your car and firmly pull the bumper off. There will popping plastic sounds, this is the pop-in-place plastic rivets that are the last pieces that hold your rear bumper in place.
4helpful
How to replace the rear bumper cover on a Chrysler Pacifica
1. Open liftgate. 2. Remove both taillight assemblies by removing 2 hex-head bolts located in the area revealed when the liftgate is opened. 3. Remove 4 plastic retainers on the very bottom of the bumper cover in the rear. 4. Remove 2 phillips head screws in the wheel well rear lip. 5. Remove 4 pop-up plastic retainers in liftgate area. Use two screw drivers to lift the head and then pull the entire retainer out. 6. Remove a hex-head bolt from each side in the area revealed when the taillight assembly was removed. 7. Bend the bumper cover outward on each side to clear the wheel well lip and remove the bumper. Have a blanket or carpet on the ground to protect the bumper. 8. Remove metal clips from tabs that connect the upper bumper cover to the lower bumper cover. 9. Drill out pop-rivets that connect upper bumper cover to lower bumper cover. 10. Push tabs out of slots to separate the upper and lower bumper covers. 11. Release tab locks on chrome trim pieces and remove from upper bumper cover. 12. Reverse this process to replace the bumper cover.
7helpful
2answers
Need step by step instructions on how to remove a rear bumper cover on a 2007 nissan altima
Rear Bumper: Service and Repair
REAR BUMPER
Removal and Installation
REMOVAL
1. Remove the LH and RH rear combination lamps.
2. Remove both the rear wheels and tires.
3. Remove the LH and RH splash shields.
4. Remove the rear bumper fascia clips and screws, then remove the rear bumper fascia.
5. Remove the rear energy absorbing foam.
6. Remove the rear bumper reinforcement.
7. Remove the rear bumper supports.
INSTALLATION
Installation is in the reverse order of removal.
8helpful
How to remove the rear bumper on a 2005 Kia Sedona
1. Remove rear combination light assembly. A. Remove two mounting screws. B. Disconnect electrical connector from rear side of light assembly. bs6d007a.gif 2. Remove bumper assembly. A. Remove four fasteners and four retaining screws from top of bumper assembly. bs6d007d.gif B. Remove mud flap from bumper assembly. C. Remove two screws from bottom of bumper assembly. bs6d007e.gif D. Remove two screws from side of bumper assembly. bs6d007b.gif E. Remove four bumper mounting bolts from under of vehicle. bs6d007c.gif 3. Install rear bumper in reverse order of removal.
Top Honda Heating & Cooling Experts
Paul Carew
john h
Are you a Honda Heating and Cooling Expert? Answer questions, earn points and help others
