Probable failure of the main power supply module which will be a separate assembly attached by several flat cables to the various circuit boards.
The supply will have substantial aluminum surrounding larger than average parts. There is almost always a paper sticker with the assembly/model number and possibly another company's name since these are designed and built by many different companies.
These are repairable and if done honestly, could cost less than $50 US for parts and labor.
Depending on the age of your set, new supplies may still be available from or through LG but will likely fail in the same way in a few years..
SOURCE: LG 36" LCD Flashing Picture
Most likely cause:
Backplane lamps, and or the backplane power supply is defective.
I don't know the particular model, but in most of these models, these parts are replacable. I suggest giving out the set to a tech who is experieced at doing this type of work. The parts would have to be ordered from the manufacture.
Jerry G.
SOURCE: standby light flashes twice
The power supply board may have been damaged. Try leaving the TV unplugged overnight so the Tv can discharge and reset itself. If this doesn't work, the power supply board may need to be looked into by a TV repair shop.
If you have some electronic experience and wish to try to fix it yourself, you can most times find a Service Manual for your TV over the internet for less than $20. It will have schematics, diagrams and parts list for your TV.
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
SOURCE: 16" lcd new out of box flashing blue light on power indicator
Under a year old tv?This tv have power supply problems.Call the for warrenty repair.Or tries websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
