Question about Ovens
Beko built in double oven alarm after power outage
Had a power outage and when the power came back on the alarm on the oven sounded. The display is also flashing but I am unable to reset anything as none of the functions work. I have tried turning it off at the mains but that makes no difference. The only way to silence the alarm is to switch it off at the mains. Can anyone help please?
    New Friend:
    Problem Solver:
  • 9 Answers
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Posted on Jul 05, 2015
  • Anonymous Jul 05, 2015
    Thank you for taking the time to reply to my question. Sadly since the power outage non of the function buttons are working so your solution hasn't worked in this instance.
6ya staff
SOURCE:
After a power outage, the oven control light keeps flashing.
You have too reset clock pressing two buttons works for me
Nov 09, 2015 | Ovens
My Westinghouse 668 wall oven won't allow me to set the time. We had a power outage and I have checked the power and it's fine now. But the display flashes between 0:00 and auto and I can't hold the two...
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
Nov 06, 2014 | Ovens
I have a GE model JGBP335 gas oven. Since power outage about 3 wks ago it flashes "unlock door" when you try to preheat oven. The oven will not come on at all. We have tried unlocking and locking door...
I would suggest set unit in self clean then cancel, this should rotate the lock and reset the lock position for you, apparently the unit was in a cycle when the power issue accrued and is unable to reset on its own. Try this and see if this corrects this issue for you.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 06, 2013 | Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
Cannot get display clear on kenmore oven
Unplug the cord behind the oven. You'll need to pull out the oven a bit. Not too far as the flexable gas line is there also. Wait 10 min and replug the oven. This will reset the curcuit board after the power surge.
Apr 29, 2009 | Ovens
F8 code
It is a " Lock Switches" Display you can try to disconnect power and resetting. But it is possible with the power outage you may need to replace
Jul 24, 2008 | Kenmore 41389 Electric Double Oven
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
224 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
