The first link is a discussion page where someone asked for the manual. The second link is the manual. Apparently the manual is for a different system the works the same way. From the first link: "The 43LCD does not have an owner's manual. Instead, the manual to which the remote is compatible with is the 'manual' it is associated with, link below. "
http://www.sonicelectronix.com/item_18302_AutoPage-XT-43-LCD.html
http://contentdocs.installernet.com/documents/product/32268.pdf
SOURCE: Autopage xt42 remote fell down and resets from time to time
you will need to press the battery hold down back in.
SOURCE: i need a replacement remote XT-43LCD FCC
you can contact autopage's authorized remote replacement services at www.autopageusa.com and clicking need a replacement transmitter.
SOURCE: i need the manual to
The Autopage XT-42LCD is used to operate two systems, the RF-420LCD and RS-622. Since you state that you need to activate a remote start that narrows it down to the RS-622. You can download the manual for this unit at the following link:
http://www.autopageusa.com/resources/RS622operationManual.pdf
SOURCE: I bought a used 2007 Expedition and the door pad
I'm not sure exactly if this is what you're looking for, but if you're
trying to program a new keyfob remote, follow these steps:
As for the alarm type, you would probably want to contact Ford and ask them. As for the door pad, while you're on the phone with Ford you'll need to get the factory door code. You might be lucky and find it written somewhere in/on the car or inside the book that came with the car, unless the new owner got rid of it.
