Sewing Machines Logo
A
Anonymous Posted on Jul 04, 2015
Needle in my machine NECCHI LYDIA3 moves only half way down and looks like something is blocking to go tru all the way
R.A. Ellis
Level 3:
  • Necchi Master 12,731 Answers
  • Posted on Jul 05, 2015
R.A. Ellis
Necchi Master
Level 3:
Answers
12731
Questions
Helped
2618611
Points
59176
Here's a web site that may give you some ideas.
sewing patternreview com
Perhaps the camstack is cracked.
1helpful
I bought a 2nd hand Necchi Lydia3 544.Tried stiching but needle thread keeps breaking. Could thread quality have anything to do with it?
Yes quality of thread could definitely affect sewing, as will a blunt/old/wrong size needle for the material used. Also must have same thread in bobbin and needle also corect thread and needle size for material sewn plus correct tension for that material too. Could be lint or tangled threads underneath needle plate too.
Zigzag blocked, only straight lines
In the upper portion of the machine, there is usually a cam mechanism that moves the needle side/side during a zig-zag stitch. It's possible that a pin or something has fallen into the machine & is preventing the needle-arm from moving properly.
There are usually only a few screws that hold the upper housing cover in place. Open it up and check the needle arm movement from there. Chances are, the problem will reveal itself thru a close inspection of the moving parts involved.
1helpful
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Does anyone have a manual for the Necchi Lydia3 sewing machine
try these sites
ebay
sew4less.com
sewusa.com
3helpful
3answers
I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Cant get machine out of neutral after threading the bobbin
there should be a way to disengage the bobbin winder. I had a machine that had a switch in the center of the handwheel and even though it would be in the off position I still had to turn the handwheel till it clicked.
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
