Dishwasher ADPU 701 WH showes error code F6 E1. Stopped mid cycle. What to do ?
Error code F6 E1 on a dishwasher typically indicates a problem with the electronic control board. This can be caused by a number of factors, including a power surge, a malfunctioning component, or a problem with the wiring.
Here are some steps you can try to troubleshoot and resolve the issue:
Check the power supply to the dishwasher. Make sure that the outlet is receiving power and that the power cord is securely plugged in.
Reset the dishwasher. To do this, unplug the dishwasher for a few minutes and then plug it back in. This can often reset the electronic control board and resolve the issue.
Check for any loose or damaged wires in the dishwasher. If you find any, tighten them or replace them as needed.
Test the electronic control board. If you have a multimeter, you can test the control board to see if it is functioning properly. If it is not, you may need to replace it.
Check the water supply to the dishwasher. Make sure that the water supply valve is open and that there is no blockage in the supply line.
Check the dishwasher filters. If the filters are clogged, they can cause the dishwasher to malfunction. Clean or replace the filters as needed.
If these steps do not resolve the issue, it may be necessary to call a professional appliance repair technician for further assistance.
