I can't get the the remote to function properly
The main system control memory I on the main board of the TV is faulty. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
[2] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[3] Enter 9 - 9 - 1.The LED will blink twice.
[4] Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, UP or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
[5] To lock in the code, press and release SET.The LED will
blink twice.
[6] To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
OK.
