My KITCHEN-AID OVER THE STOVE MICROWAVE MODEL KHMC1857WSS---The door does not close tight enough or go in far enough to allow the unit to operate. The door will close and latch however the close door indicator is telling me to close the door (Door open) says "close door" therefore the unit will not operate. No matter how much I push on it after closing,,, Nada. Is there a fix for this? Thanks Carl Fixed the problem Took off the digital setting panel (front of unit and right most) Inside where the 2 pins (rectangular in shape attached to the inside of the door) slide into the slots provided I saw that the upper one had come loose and had dropped back far enough so that the upper door pin was not engaging. I just tightened the screw that holds the slot in place and "VOILAA!!!" all is working as it should. Hope this helps others with a similar problem as most makes work essentially the same.
SOURCE: Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
SOURCE: Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
SOURCE: Sharp Microwave model R-1850A door won't open
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Microwave door not closing properly so will not work
Throw it away and get another microwave
